Does anyone know if a 2001 Pontiac Aztec 3.4 V6 & 2001 Chevy Impala 3.4 V6 share the same engine and components? Someone offering to sell me a 250amp aftermarket alternator and says the both the Aztek and Impala share the same engine/alternators, a GM 3.4L V6 engine, and both should use the same alternator. Also, would an alternator for a 2004 Impala, same engine, fit in a 2001 Impala?
engines are the same i do not know about the accesory drives though they might and most likely are different, but as far as alternator GM didn't make that many different ones, just check the mounting(6&12 or 4&8 i think it is) type CS-130 or AD244 just take a look at it
1996 GMC YUKON 2dr
Eclipse cd5000
six- Soundstream T5 12's in 13^ft tuned to 30.4hz,43.04hz, and 53.53hz soundoff
149.8 on TL in kick,150.0 SEALED in kick 147.8 SB4
3 RF T5002's--------------going to 3 Soundstream DTR1.3400D's
two- Stinger sp1000's----going to two- BATCAP 4000's
2 140 amp alternators---going to 300amp Ohio Generator
2 runs 1/0ga, big 3-------going to 4 runs 1/0g + and 3 runs 1/0g -
MB Quart QSD 6.5's in doors---soon to come
my build log HERE!!!! check it out!
not sure about your car but i pulled my add-244 200 amp alt off of a 6.0 hummer in a junk yard. so i believe your accesory drive brackets should line up. hopefully someone else can comfirm this
Edit: he shoul;d have a cs130, i belive the ad244 is the larger alt for the work trucks that i took outa the junk yard
Edited by cqtama
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Have fun doing the alts on that car.
I know on our z34 Monte Carlo it wasn't very easy.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
