that guys fucking crazy
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well I don't know much about diesel engines but don't they combust under compression and need less air or something? It almost looks like there is a snorkel on the thing too.
Diesels use a compression ratio much higher than a normal gasoline car, and in having this higher compression, are able to utilize it to combust the fuel, eliminating the spark plugs from the scenario, so there are no plugs there to get wet, and if he has a snorkel atachment he solves the getting water in the combustion chamber though the induction system, which allows him to do that.
¿ǝɯɐƃ ǝɥʇ
Looked like a Unimog.
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
thats pretty badass. buy im guessing he ruined whatever he was hauling. i cant believe he would even try something like that. fuckin ridiculous
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
