I have pioneer deck. when i turn the volume up from zero the sub makes a loud thump and when i turn the stereo all the way back down to zero again it makes a thump again.
i have a a 2003 cavalier.
probably just the settings on the amp are up to high. too sensitive. idk how to describe it
Pioneer AVH P5900DVD
JL Audio XR525 CSi Components (Kickpanels)
Infinity Reference 6020cs Components (Doors)
JL Audio 12W7 Subwoofer
JL Audio e1800D Amplifier
JL Audio e4300D Amplifier
It could most likely be improper grounding of your hu... same thing happened in a friend's car, it turned out to be a loose ground cable going to the hu...
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
sounds like the dreaded pioneer rca ground issue..try grounding the outer shields of the sub rcas and see if the problem goes away...thats what my avhp4100dvd did right before the front and rear rca grounds went..then i had OBVIOUS engine noise..ive seen guys do a battery swap and mess up pioneer decks
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(4)Hertz HCX-165 (front doors)
(2)Hertz HL-70 (dash)
(2)Hertz HT-25 (dash)
(2)Hertz SX-380D
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 525 Guests (See full list)
