You have an alignment issue; nothing you can repair without proper tools.
Also, the numbers change on your meter when you push the cone in due to it's inductance.
Former USAC Director
MECP Certified First Class of 1997
First car in the world to register 150db from the dash and sealed, in the trunk of an escort, with 2 10 inch subs. In 1997:
http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=51;t=002600
Just my part in the modern development of SPL competition:)
found out today i dont think they're blown or anything hooked it up in my friends car and seemed to work fine, so my last resort is my HU, probablyh the RCA hookup went bad, how do i find out if there bad
2 JL W7's @ 1.5ohms - SOLD
Soundstream PCX2000D - SOLD
Yellow top Optima - SOLD
Stock Alt
148db @ 36hz
also another thing, they sounded fine in his truck, he even powered it around 500rms each and it didnt even distort, now i have another problem i believe its my HU causing my subs to do this because i tried hooking it up again and it didnt even work at all now, im think its my HU rca hookup
Stock Alt
148db @ 36hz
just swap rca cables... they arent that expensive...
but a good test would be a ipod with a 3.5mm to RCA cable... hook it up directly to the amplifier...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
did you accidentally cross over the two voice coil input wires..
aka reverse polarity on one and still hookin it up as normal. it will cause the coils to fight each other and just sit there and distort and sound like shit!!
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
Your'e running two amps, one to each driver? Or, one amp in stereo to them? Did you not try switching rcas before hand, or drivers?
i swapped rca's still the same problem, i dont have a ipod they're junk sry
Stock Alt
148db @ 36hz
try pulling your head unit out of the dash a little ways and wiggling the rca jacks at low volume and see if it makes any noise difference...
your symptoms could be either from bad outputs or bad rca's.... i would definately pull the rca's and inspect them for pinches, cuts or bare spots...
3 Kinetik Hc2000's
Dual 200amp alts.
well i didnt necessarily mean an ipod... any mp3 player or portable cd player(if they still even exist) will suffice...
what HU are you running? and how old is it?
also... if your hu has more than 1 set of pre outs... you could hook it up to the rear out to see if that makes any difference
3 Kinetik Hc2000's
Dual 200amp alts.
no i have one amp a pcx2000 d 2,000rms @ 1ohm, and 2 jl W7's 12inch they were both on the amp @ a 1.5ohm load running about 800rms each a piece.
i dont know if either the rca outputs are bad on my HU or amplifier, but when i hooked them up on my friends amplifer in his truck it sounded fine and didnt distort, it was distort so bad in my car it actually sounded like they were blown...but they werent
Stock Alt
148db @ 36hz
  • Who's Online   0 Members, 1 Anonymous, 964 Guests (See full list)
