So I was just doing a little tuning on my system because I just replaced my mids and highs amp. I'm now running a Sundown SAX-50.4 to my Type X 6.5" comps (bridged to 2 channels and running passive). Anyways, I'm messing with all my HPF, gains, etc. all with bass boost off on the HU, EQ flat, loud off, etc. I get it close to where I like it (close enough for now anyways). I'm using HU volume 40 out of 50 as my highest listening volume, so I still have some headroom. Still gotta bust out the DMM and check my gain settings.
Now to the question: what exactly does the "loud" option do and why is it bad? My guess would be that it just boosts the lower and higher frequencies (also make the HU start clipping earlier)? Cause I'll be damned if it doesn't sound better to me. I turned it on Low (my HU has low, medium and high) and I thought the bass was much fuller and highs seemed clearer. I know everyone says to avoid it so what I'm wondering is what are some tricks to get that fuller sound without using the loud level? Is it a matter of manually boosting EQ and whatnot? With loud being turned off my components are still loud, but the midbass seems lacking and the overall sound is just....thinner I guess.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
Loud function = clipping
Keep it off.
Do you have your doors deadened? That will dramatically help with the midbass.
Vehicle: 2001 Dodge Dakota
Headunit: Alpine IVA-D310
Sub: 2005 RE Audio XXX 15"
Sub Amp: Orion 2500D
Frontstage: Diamond Audio Hex's
Frontstage Amp: Sundown Audio SAX-100.4D
Wiring: Kicker Hyperflex 1/0
Alternator: Mechman 250 Amp
Battery: Powermaster D2700
Deadener: 100 Square Feet Raamat BXT II
The loud button is an internal eq setting, most HUs have them. It was originally designed to overcome road noise when listening @ low volume levels.
The loud button does not cause clipping, but you will drive your outputs to clip sooner with it on due to the additional gain of the signal.
Former USAC Director
MECP Certified First Class of 1997
First car in the world to register 150db from the dash and sealed, in the trunk of an escort, with 2 10 inch subs. In 1997:
http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=51;t=002600
Just my part in the modern development of SPL competition:)
Yes, loudness makes up or the lack of highs and bass at lower volumes. On some head units, loudness rolls off once the volume is turned up past a certain point. I don't know that it necessarily means clipping, until u get to a certain point. Clipping will occur sooner though. My hu doesn't clip ever so I can't really say. Check it out with an oscope to be sure, as of course all hu's are different.
Eclipse cd7000
Yeah I don't have an oscope, nor can I really afford one.
My doors are deadened a bit, but I'm going to do some more work on them when it warms up. My main problem is that my woofers mount directly to my door panel (there's not really a way to mount them to the door frame) so I'm thinking about glassing the backside of my door panel to really harden it up and give it some weight. I'm hoping that will help with the midbass output.
There's quite a dramatic difference between having loud on low and putting it on medium and high (which sound like poo). Obviously I don't want to clip my signal and stress my components, but it honestly still sounds pretty clean to my noob ears. I don't usually drive my stuff to hard nor do I listen for long periods of time.
Pioneer DEH-P6000UB
Sundown SAX-50.4
Sundown SAX-1200D
Stock Bose system
Profile AP1000M
So today after tweaking it a bit I got it sounding better. I turned the loud all the way off and bumped up a couple bands on my HU's EQ. It's a seven band and I bumped the 50 hz, 125 hz, and the two highest ones (only increased them by one each) and it honestly sounded a lot better than a totally flat EQ. It was not as dramatic as loud:low so I think it's a happy medium.
I really need to do something about my door panels, though. I can see and feel them vibrating from the midbass and I'm sure it's hurting output. You guys think putting a few layers of glass on the backside of the panel would be a good way to go about stiffening the panel up and reducing some of the flex?
I have a a few layers of deadener on the back of the panel near the woofer but I don't think it did much.
Pioneer DEH-P6000UB
Sundown SAX-50.4
Sundown SAX-1200D
Stock Bose system
Profile AP1000M
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
