New Pics Added 6/27
So i finally got rid of my old setup (hence the name CVXsmitty58). I am 3 hours away from home at college so i had to get as much work done i could last week, along with working 8-10 hours a day for my dad. I ordered my Btl today and i already have the amp so hopefully i can put it all in when i go home in 2 weeks. baffle will be 3 layers thick and the 45's will be filled with expanding foam and glassed in the corners. I dont have a picture of the 1/0 going to the back but it's already done. Any input on the setup is appreciated. And if i need more bracing on the box please let me know.
What I came home to find after 2 months away at school.
Size of the battery. This thing is huge.
Big Three
Front of box. About 7cf at 34hz
Back of box and Amp/battery Rack
Do you plan on upgrading front batt also so that front and back are of same chemistry?
Edit: looks good so far but how are you getting a 7cuft box and the way the battery and amprack are under the windowline?
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
The only thing I see you needing bracing on is from the 2 T's to the back wall. But looks good so far
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
Within the next 6 months i will. And the box is extremely close to not fitting. Mabe an inch of clearance between the tailgate and the box. it was the only place i could fit the battery and amp.
I thought it was gonna be close... but you don't want the port that close to the liftgate. You could put the battery in the spare tire well and the amp flat on the box with rubber mounting feet to absorb the viberations. Then slide the box upagainst the seat for more port clearance. Just an idea I'm sure yopu thought of
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
I was worried about it but then i saw how close the port was on Justin's Yukon so i wasnt to worried. I thought about the spare tire well but i get worried about stuff like that especially since i drive 15k miles a year. Not that having 300 pounds of shit above the spare tire helps. If the port sounds shitty there ill probably end up porting out the top. Jeep cargo areas suck. I appreciate the input.
Edit for thanks
Look'at this guy. With his jeep. Get realll.
Lookin good big smit.
GMCEnvoy2002
Lows:
Fi 18BTL(In transmission line box)
AudioQue 2200D(AudioQue 3500.1D on the way.)
Highs:
6.5 JL C2 Component set up front doors
6.5 JL C2 CoAx's in rear doors
AudioQue 90x4
Headunit
Alpine iDA-X303
Wiring:
KnuKonceptz KMLX Power & Ground
KnuKonceptz Karma SS Speaker Wire
Electronics:
2 Optima Yellow Top Batteries
300a Iraggi Alternator "Dominator" Series (On the way)
Stinger Gold ANL Fuses
Stinger Fuse Holders
we needs more pix
R.I.P!
(Nov-29-2009)
92 explorer
current build
what do you think of the shuriken batteries? ive been debating getting one lately. badass build though man. this should sound pretty damn good. what amp are you gonna run?
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
