im kind of new to car audio, but have been doing a lot of research and reading, trying to teach myself best i can.
im am about to receive a 18'' solo x, dual 1 ohm, (1&2 ohm)
along with that i will receive a audio pipe 30001d amp
heres info on the sub
http://www.onlinecarstereo.com/CarAudio/p_18697_Kicker_SoloX_S18X1.aspx
and info on the amp
http://www.echo-electronics.com/audiopipe-ap30001d-p-1131.html
what my question is how will i wire this for 1 ohm? how will i wire it for 2 ohms? should i wire it 1 ohm or just run it at 2?
right now my electrical is stock, but i will be getting a ho alternator and optima yellow-top.
i already have wires ran, and the are correct, (basic wires from battery to amp and ground and all that.) i just need help with wiring the amp to the sub.
Work in Progress:
Custom '93 Nissan 240sx painted orange with custom orange & black interior.
18'' Kicker Solo X in a 6.6 cubic ft box, tuned to 35 hz
AudioPipe 3000 amp - possibly another sometime in the future
Shitty wire -knu 0g coming very soon
Stock alt - iraggi 200 amp alt coming pretty soon
optima blue top - xs power coming soon
suggestions? shoot me a pm.
You can't wire dual 1 ohms @ 1 ohm...
it's either .5ohm(parallel) or 2ohms(series)
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
unless you buy another identical amp and do 1 amp per coil.......
1998 jeep grand cherokee
future teardown and rebuild:
2-15.4 orion hcca's
sub amp undecided
2 sets of components
1-concept amp (mids/highs)
undecided h.o. alt
2-yellow tops
so could i safely run this at .5 ohms?
Work in Progress:
not if the amp isnt rated for it. sure it might play for a while but chances are it will either cook itself or go into protect mode. and you will void the warranty if you have one.
2-15.4 orion hcca's
sub amp undecided
undecided h.o. alt
2-yellow tops
but then you wont have enough power....
2-15.4 orion hcca's
sub amp undecided
undecided h.o. alt
2-yellow tops
check the specs on that ap3000d if i'm not mistaken that amp is only rated at 2 ohms.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
Product DescriptionAP-30001D Class-D Amp, 3000 Watts
1000W RMS x 1 @ 4 Ohms
2000W RMS x 1 @ 2 Ohms
3000W RMS x 1 @ 1 Ohm
1 Ohm Load Stable
Overload & Overheat Protection
2 Amps Can be Linked Together
2-15.4 orion hcca's
sub amp undecided
undecided h.o. alt
2-yellow tops
thanks for all of the help and feed back. i appreciate it a lot.
for now ill juss keep it at 2 ohms, till i get the cash to get another, then i will link them together.
how do you think a stock alternator w/ a decent battery will run this? what is the bottom amount of thing i will need to run it at 2000w rms?
Work in Progress:
