boogie0410 Posted March 12, 2010 Report Posted March 12, 2010 got a question i'm thinking of buying a crunch p1500.1 and a crunch p1100.2 amps but before i do that i need to know if a stock alt will power it and if not what size alt do you recommend
jizazz12 Posted March 12, 2010 Report Posted March 12, 2010 don't think you would need a HO alt for what your wanting run.I was running 2500 rms on stock electric and a kinetic hc800 in a 05 sonata,just do big three upgrade and see where your at if anything you might need to add a second battery. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
boogie0410 Posted March 12, 2010 Author Report Posted March 12, 2010 thanks how do you run a second batt
imupabove Posted March 12, 2010 Report Posted March 12, 2010 don't think you would need a HO alt for what your wanting run.I was running 2500 rms on stock electric and a kinetic hc800 in a 05 sonata,just do big three upgrade and see where your at if anything you might need to add a second battery. sorry for butting in. do you remember the amps on that stock alt? what size gauge you use for the big 3? im jes curious. thanks. iDA-X200/Clarion EQS746 RF T500-1bd (2) 12" RF HX's Kicker 350.4 Alpine & Polk Speakers Stock electrical
jizazz12 Posted March 12, 2010 Report Posted March 12, 2010 thanks how do you run a second batt just run a + run from first battery to the second,and you could run - from front to back as well or do what i did and find a good solid grounding point in the trunk or wherever your going to place second battery and thats it so + to+ - to- . 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
jizazz12 Posted March 12, 2010 Report Posted March 12, 2010 sorry for butting in. do you remember the amps on that stock alt? what size gauge you use for the big 3? im jes curious. thanks. to be honest i'm not real sure what size the stock alt was on the sonata,but i used 0/1 stinger pro for big three and the same wire for all my runs. stock alt couldn't have been much more than 105 amps if that. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
imupabove Posted March 12, 2010 Report Posted March 12, 2010 to be honest i'm not real sure what size the stock alt was on the sonata,but i used 0/1 stinger pro for big three and the same wire for all my runs. stock alt couldn't have been much more than 105 amps if that. dang a 100 amp, wish mines was kinda up there. i gotta stock 70a and a duralast battery >.< i do get voltage drops from 14.6 down to 12 ouchy. i did the big 3 in 4 gauge, would it help out my voltage if i got like a HC600 in the trunk? or should i replace my battery under the hood with like a HC1800? iDA-X200/Clarion EQS746 RF T500-1bd (2) 12" RF HX's Kicker 350.4 Alpine & Polk Speakers Stock electrical
jizazz12 Posted March 12, 2010 Report Posted March 12, 2010 dang a 100 amp, wish mines was kinda up there. i gotta stock 70a and a duralast battery >.< i do get voltage drops from 14.6 down to 12 ouchy. i did the big 3 in 4 gauge, would it help out my voltage if i got like a HC600 in the trunk? or should i replace my battery under the hood with like a HC1800? if your still running a stock battery under the hood i would def look into getting a better battery there, try that first and if your still having problems add a second.and remember the four gauge is a good start but bigger wire means more currant flow, so you might want to think about using o gauge for the upgrade at some point. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
baaudio Posted March 12, 2010 Report Posted March 12, 2010 i think a second batt and run 0 gauge with your 4 in your big 3 and see where your at with it Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
