:bull:
what are you calling BS on? just curious for your input.
Build in progress:
Kenwood DNX890HD
Rockford Fosgate White wolf RCA's
2 Rockford Fosgate T400.4 on RF fanatic q components (6.5 in the kick, 6.5 in the front doors, 5.25 in rear doors)
2 Rockford Fosgate T2500's on sub
1 Fi car audio Team 15 D1
XS Power D3400 and three D975's in the rear
Mechman Elite 370
Stinger power connections and cable
I'd run two runs of whatever I have from alt to battery regardless:) depending on length and how warm the engine actually gets... Wouldn't hurt to do it!
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
the alternator to the battery + wire only needs to be one 1/0 wire. the length of it will be short enough to handle the extra current. just be sure to fuse it.
your starting battery is under the hood, correct?
two runs of the CCA wire should be done from the front battery to the rear battery (if you want full power potential)
Upgrading your grounds is always a big plus. do as many grounds as you can from your frame/motor/alternator to your battery. grounds are often over looked. electricity works in a circuit, so if the ground restricts your flow at all, your alternator will not be able to move the current as well.
hope that helps clear things up a bit for you.
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
clears up alot of things, im going to be running a 300A alt, what would you fuse this power lead at?
Build in progress:
Kenwood DNX890HD
Mechman Elite 370
i have the same wire on my 250amp alt and its fine. if you left the stock + wire on the alt then that should be able to hold at least 110amps so itll easily make up for that 50amps your worried about.
exactly^^
i'd do a 300amp fuse on the one run from your alt to your front battery. if you want to be extra safe, toss a 250amp in and keep some spares with you in your car.
Edited by J00bles
exactly^^
K, thats kinda what i was thinking, Thanks for getting this straight for me guys.
Build in progress:
Kenwood DNX890HD
Mechman Elite 370
i have nothing but the knu klmx wire in my truck and have had no trouble, i have 4 runs from front to rear, two pos, two neg, 290 amp alternator, and 2 ap 3000d's, wire never gets hot, i love it
Sweet, this makes me feel alot better about my purchase, i thought i had messed up there for a second LOL.
Build in progress:
Kenwood DNX890HD
Mechman Elite 370
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
