Noob Mistake What Should I Do
Amalan
i didnt see any sparks tho so i dunno... im not disagreeing with you i just want to know why i didnt see sparks
when i first started with audio systems i smoked a shit lot of fuses by not unhooking my negative on my battery or negative on the amp. i've seen guys try and hook the positive up reall quick and fuses pop. rule of thumb, either unhook the battery negative or the amp negative first and hook either or back up last.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • 4 months later...
sorry for bring this up back from the dead but i kind of need help now. the guy wants his system installed soon but i cant figure out whats wrong with this amp. i took some pictures of the insides. i didnt see anything burnt if anyone needs bigger pictures pm me.
bottom left
bottom right
top right
top left
i dont see anything unusual so im not sure whats wrong here.
on the ground thing...rule of thumb YES but necessary......uhhh no. I dont know how anyone would blow a fuse by leaving the battery grounded. You WILL usually see a small spark but that is just the caps inside the amp sucking up juice when you first add power to it. Nothing to worry about. You will see the same spark if you hook the ground on the battery last...
leaving that ground on didnt do any damage to the amp dont worry. What you need to worry about is (obviously) making sure the pos and neg are correct.
Follow my Tweet (Twitter)
they were plugged in correctly im not sure but i think the amp may need to be fixed.
You bench test that bad boy?
lol well theyre powering 2 10in visoniks which i got at pepboys for 30 bucks for the pair so the amp is a perfect match.
  • Who's Online   1 Member, 0 Anonymous, 1432 Guests (See full list)
