OrionStang Posted March 24, 2010 Report Share Posted March 24, 2010 I need some help with checking theses numbers. I thought I know what im doing , but I got no reading at all on one coil and the other coil had the numbers jumping all over. Can someone help verify what setting Im supposed to use on my DMM. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
bassl0va Posted March 24, 2010 Report Share Posted March 24, 2010 the one that measures ohms. it looks kinda like a O that has been split open at the bottom. touch the leads together, you should get like 0.4 or something real small. then touch it on the coil, you should get like 2.3 (for a 2 ohm coil) then minus off the lead resistance. ending up with 1.9 (dc ohmage, resistance, is normally a bit less than ac ohmage, impedance) My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades. Link to comment Share on other sites More sharing options...
fr34kout Posted March 24, 2010 Report Share Posted March 24, 2010 I need some help with checking theses numbers. I thought I know what im doing , but I got no reading at all on one coil and the other coil had the numbers jumping all over. Can someone help verify what setting Im supposed to use on my DMM. Ohm symbol looks like this: Use the setting with that symbol. Link to comment Share on other sites More sharing options...
OrionStang Posted March 24, 2010 Author Report Share Posted March 24, 2010 Ok, I got that part, but my DMM has different ohm settings; 20, 200, 2000, etc. Do I use the smallest one? SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Neo_frog Posted March 24, 2010 Report Share Posted March 24, 2010 You should use the one closets to the numerical value of 1. Some of those DMMs are used to measure milliohms and centiohms. You are going to measure full ohms Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
OrionStang Posted March 24, 2010 Author Report Share Posted March 24, 2010 OK, I got it. One voice coil is right at one ohm(good). The other is giving no reading at all(bad), what does that mean, voice coil dead? SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Neo_frog Posted March 24, 2010 Report Share Posted March 24, 2010 Infinite means there is no connectivity. A 0 ohm reading means a possible short. Blank means a broken DMM. lol Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
OrionStang Posted March 24, 2010 Author Report Share Posted March 24, 2010 Sucks. Oh well, I can start the summer build early I guess. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Boon Posted March 25, 2010 Report Share Posted March 25, 2010 Check your tinsels and terminals. Bad coils usually just read high or low, not so often that they read Open. 10.x volts fo' life! Link to comment Share on other sites More sharing options...
