Has each different HU you tried been different than a Pioneer? Pioneers are notorious for the engine whine...
the noise is present with the rcas unhooked from the cd player. I'm pretty sure it's not the deck.
God damn its hot today. My balls are stuck to my leg.
dont know where that last post came from. Anyway, it gets worse when rcas are near fuel pump under back seat. Tried running them up the a pillers through headliner then back down rear window pillar.
Posted (edited)
I had a slight whine occasionally some how it turn into horrible alternator noise... It got to the point where I tore all my interior out and meticulously laid the wires and RCAs out, also using my 360.1 I have 0 noise, none whatsoever.
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
Posted (edited)
i had this problem once. the speaker terminals in my doors were touching the metal on the doors. so this could be happening with you or if its a new noise and you didnt change anything then look at your speaker wires. maybe they are grounding out somewhere.
edit, an easy test here would be to hook up a spare set of speakers at the amp. unplug your door speakers, hook up the stock ones just sitting on the floor.
Edited by skittlesRgood
i wish it were that simple. There are definitely no terminals touching. they are on wooden spacers where they cant touch. But I took them outto check just in case. this isn't a new noise. I have had a noise problem with this car since 2001. I just keep it loud enough not to care most times. I even checked to see if the amp was touching metal from mounting screws. I read something similar on a termlab forum post where a guy with a 95 civic had the same problem. Never saw a solution. It must be the g*ddamned extraterrestrials again. Shit.
but you didnt check the speaker wires all the way through did you?
i cut them and ran new ones. Wires are only 6-7 feet long and laying over the carpet tucked behind the edge of the door panel. there is no way anything is touching.
if there were wires touching you would know lol...you wouldnt have speakers anymore :D
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
