Sactownbully84 Posted March 25, 2010 Report Posted March 25, 2010 i was looking into these 14v batts xs has how would i go about running a system in my grand am with these? i have no clue where to go or what it takes any xtra info would help thanks 2001 Grand AM Pioneer UB4000 HU Tsunami / Monster Wire's DC POWER INC 260SP ALT w/ XS Power VCM BIG 3 All 1/0 Monster 400 + YT Under Hood Stinger SPV70 x2 in Trunk 4x SA-10's On There Way soon i hope SS XXX-4000D @ .7ohm 3K+ RF Power 4x6's & 6x9's Monsoon Powered PG TL22 Line Driver 148.7db @ 35-45hz sweep w/ 12" BTL
cvxsmitty58 Posted March 25, 2010 Report Posted March 25, 2010 well to be quite honest i think it will be the same as a 12 volt system. Lots of guys on here are running in the 15 volt range on a 12 volt system. I dont know much at all about those batteries but they probably just sit higher when not being charged.
chill phil Posted March 26, 2010 Report Posted March 26, 2010 XS power sells a voltage regulator that you attach to your alternator and makes your alternator charge @ 16 volts. 2007 Nissan Xterra SE Amp: Sub: Box: Electrical: TL Scores:
05AccordLover Posted March 26, 2010 Report Posted March 26, 2010 So would this give you extra power to run the system longer with out reving the engine????
crazyfrazz09 Posted March 26, 2010 Report Posted March 26, 2010 you may also want to consider that not all amps like to see over 14.4 volts. some can go up to 18. just a thought. 1998 jeep grand cherokee future teardown and rebuild: 2-15.4 orion hcca's sub amp undecided 2 sets of components 1-concept amp (mids/highs) undecided h.o. alt 2-yellow tops
Neo_frog Posted March 26, 2010 Report Posted March 26, 2010 I spoke with Matt about this a while back.. Basically if you do not have the option of running a 16V setup, but you want more power, switching to a 14V system is the safe way to go. The car, amps, and accessories generally have no problem running a little over 16V charge. You would just need to swap out with 14V batteries (like D1400) and use a VCM to regulate around 16V running. My only issue with it would be getting accustomed to a 14V low end. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
mbdblue Posted March 26, 2010 Report Posted March 26, 2010 I spoke with Matt about this a while back.. Basically if you do not have the option of running a 16V setup, but you want more power, switching to a 14V system is the safe way to go. The car, amps, and accessories generally have no problem running a little over 16V charge. You would just need to swap out with 14V batteries (like D1400) and use a VCM to regulate around 16V running. My only issue with it would be getting accustomed to a 14V low end. ah Im glad you chimed in about this. I saw on the website a little while back that they were sellin these and didnt know why. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
melonhead Posted March 26, 2010 Report Posted March 26, 2010 So the easiest way to get a 14V system is to just get a 14V batter and a vcm? That's it? What if the 14V battery doesn't fit under the hood?
Derrick824 Posted March 27, 2010 Report Posted March 27, 2010 The XS Power D1400 14v batteries are fairly small in size. Contact Matt at Mechman about a setup like this. He sells all the needed components and is running a 14v setup in his truck. D1400 size Length – 10.24 in Height – 7.20 in Width – 6.65 in http://www.stevemeadedesigns.com/board/topic/71134-14-volt-battery-demo-video/
melonhead Posted March 27, 2010 Report Posted March 27, 2010 The XS Power D1400 14v batteries are fairly small in size. Contact Matt at Mechman about a setup like this. He sells all the needed components and is running a 14v setup in his truck. D1400 size Length – 10.24 in Height – 7.20 in Width – 6.65 in http://www.stevemeadedesigns.com/board/topic/71134-14-volt-battery-demo-video/ Thanks. That battery might just fit under the hood of my Civic. My Civic takes a group 51 battery which is pretty damn small but that 1400 is pretty close in size. I currently have an Optima yellow top and still have a tad more room. I'll definitely look into this 14V setup when I upgrade to a bigger sub amp because I'll need it. I'll probably need to replace the 70A alternator too. I just did the big 3 and after an hour or so of bumping my lights start dimming again.
