I guess this thread is for anyone with the 9500G motors, or motors that have a really tight ID/OD for a coil .
I had a guy come up to me, and wanted his 9500Gs reconed to handle more power, thought I had the right coils, but they would have been to tight on the inside gap.
So I have some coils on order, they are a slight upgrade from factory, still copper, but using 2.25"ww over the factory 2", and flat copper, 4 layer with 3.018" ID, and 3.245" OD, 4.7" former height
These coils should be able to fit from 10" - 15" maybe the 18" as well
The advantage over factory coils is more throw, and should have a higher power handling.
I only need 2, maybe 4, but stuck buying 12min -anyone interested in a kind of group buy?
or just interested in buying a few?
Costs will be about $25 each+ shipping
No pictures yet, because the factory still has them
Edited by Forevrbumpn
will this fit the HDC subs?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
That Iam sure of, the HDC subs have a wider gap than the DDs do
but still a little tighter than more common coils
It will fit the HDC motor.. I have put a coil with a 3.3" OD in a few subs I have built with those motors.
Team S.S.C.
DB Drag Street A 2011 National Champ
DC Audio Dealer
Nor Cal AA Dealer
Incriminator Audio Dealer
CA Sundown Audio Dealer
[email protected]
Still looking for someone to do a group buy with these coils
I know Ssackets in, anyone else?
Did you find specs of it?
Normally im not nice enough to give them out, but your an exception :)
I have both a 9500G and a 9500D flatwound coil (same coil used in the 9500Z also).
If you need peramitors, i can grab the caliper from work, or even ship the coils off to you!
I have a coil design up and ready for winding
3.018" ID
3.245" OD, 2.25"ww ( longer than factory)
I tried everything with DD, THEY SEAR they dont make anything but these simple round wire copper coils for them. I tried and tried to get them upgraded, they wouldnt do Z coils, and they wouldnt do flat wire- This is when I had the customer try and get recone kits that are upgraded from stock, then I called them again, talked to Jack, and about 3 other guys, the 9500G motors, they wont do upgraded coils for
3.018" ID
You speak to Brad at all?
Anytime I call for orders or support, I always shoot for Brad, even tho Jack is our salesrep.
The flat wire coils that I run in my D's are a bit bigger on ID and OD however then the G series, and at glance from the 9500Zs that where chilling on my table appeared to be idenical to the D coils I run. The G coil I have is also round. dual 1 iirc. Coil is like brand new, just burned tinsels iirc.
And every G recone Ive ever done was round, not too sure if the flat is available tho. Maybe not just due to gap spec.
But if theres any info I can get for you, just hit me up, you provide a good service for people at great prices, so anything i can do to help I will :)
Edit: PS:
In your recone thread, you gave me a great idea for shimming. Most the times I use a manila folder or clear transparency sheets. Never thought about the for sale type signs. I think that would work a bit better then having to overlap other items to get a thicker shim!!
Edited by Audiofanaticz
well, the guy bought recones last week, but Iam stuck buying these coils anyways. So I would say I got screwed, doing the recones for free now, and stuck with a bill
He just got D1s, instead of the factory D0.5ohm coils
wait so how many coils do you have and how much my boy just blew 1 of his coils on his 9515 pm me if possible
Greg,
Triple C Auto Niagara Falls NY
Under construction
2002 Chevy Suburban
pioneer 8000NEX
3 Sets of ARC Audio 6000 components in custom front doors
2 Powerbass midrange in center council
4 Super tweets
2 Focal 900.6 6 channels
4 American Bass VFL Comp 15's (currently running 2)
DC 12.0k
DC Power dual alt bracket
2 XS Power D3400's under the hood
3 C&D technologies 110ah in rear
along with multiple runs of 0 AWG OFC
  • Who's Online   1 Member, 0 Anonymous, 4240 Guests (See full list)
