what is the advantage to strapping 2 amps if you have 2 dvc 2ohm subs you can wire them both at 2ohm to 2 strapped amps but how is that better than wiring them individually at 1ohm to each amp
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
only hve to set one gain
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
The issues comes down to phasing. With two woofers sharing one enclosure and having two different signals can sometimes give you one more power than the other if you don't balance the gains right. If that happens it can cancel out ultimately losing volume/output, even possilby damaging your woofers.
Strapping isn't an easy fix but, can definitely solve the phasing problem. However, normally strapping requires specific impedance from the woofers and depending on what amps you still may have to adjust the gains correctly.
Now if your looking for power advantages for each is own. I hope this was helpful and not to confusing. Good Luck Bro.
thanks for the reply helps alot
  • Who's Online   0 Members, 0 Anonymous, 1341 Guests (See full list)
