don't go to low with that much camber, my buddy's hub broke going 45 with no brakes
see the skid mark ;)
Wouldnt be thehoe92 without teh purple
What a waste, all cars with excessive camber look to me like that broke ass vw, I dont have a static drop on my truck, so when its up there is a little positive camber but when its at cruising or dropped. Camber is normal.
its not...its an illusion.
how is that an illusion all those rims are bent from hitting the curb or something!! look at them wtf you cant tell me thats an illusion i know better. :angry:
why are they all bent?
my system
2 12" diamond d3 subs
Kenwood 500 watt class d mono amp
On 4/14/2010 at 5:40 PM, Boon said:
Waaaaaa my system has a minor issue that I can't figure out so I'm gonna quit audio.
Fucking weak man.
wow.
its called negative camber. it happens when you lower a car usually cause the control arm adjust the wheel like that i believe.
but it can be fixed easily.
Okay, the skinny tires in wide wheels was done to strengthen the sidewalls while drifting. Vertical sidewalls have a tendency to break the bead during high speed slides.
I'm pretty sure none of those FWD VWs are going drifting anytime soon.
[HOONIGAN]*
'01 Ford F-250 LWB
JVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
they arent "bent". its the negative camber that makes it look like that...hence the title "can someone say negative??"
the wheels arent "bent" at all.
4 - 15 Sundown Z v.2 @ 35Hz
2 - AP3000D
2 - RF Power Punch 6.5 Comps
2 - RF Power Power
1 - Kinetic KHC2000
3 - Kinetic KHC2400
Iraggi 300A
Knu Wiring
It seems like that tire stretching has the bead already halfways off, I thought the drifters used that to get a wide wheel in there, but used the smaller tires to make it easier to break traction with lower horsepower cars? Either way no those vws aren't going drifting.
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1620 Guests (See full list)
