Box outside dimensions will be 12 x 20 x 38
The black area is 1 inch wide all around. The green area is the entire port which is nearly the whole box, each area is measured in its entirety and the 45 angles were not accounted for. I am planning on three 10s right now for my car, i could have larger subs but in order to have more space in my trunk and not have to modify my trunk in any way then 12 inches is the tallest i can have the box allowing me to have it as close to the back seats as possible. I was wanting a 1/4 or if i have to at least an 1/8 wave Tline box. I hope i did the design right, i have seen where people have made subs firing into the port directly and thats not as good, so thats why I have the small opening into the actual port area from the sub area. The specs I drew this up on were 37 Hz i think with a 10 inch sub.
I am curious what others think and if they think this will work. I understand with more subs you have to account for adequate cubic feet for each sub and port area, so I am hoping these will work alright in this box.
looks like not enough space for the woofers and the port end is choking them off.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
I would suggest increasing box space and decreasing port length. Stick with a simple ported box and use a basic box calculator to help you.
Ed Lester
ShowtimeSPL Host
My old Build Log
how do u learn how to make perfect sub boxes is there like some kind of school and is all just math??
Ummm... LOTS OF PRACTICE/TESTING/EXPERIENCE.
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
the way you have it is similar to a couple t-lines ive seen, but your opening into the port seems much too small. you should look into a tapered t-line.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
looks like an attempt at a tline?
If you did this as a tline, you would have phase issues
as a ported box, phase issues
as HHR said, going with ported, do ported, shorten port length, and increase box size/airspace
if doing a tline, the back wave of every woofer will need to have equal pressure entering the port/line or you will have phase issues with the box
practice/testing/experience/failing
lol thats the best way to learn
apparently you dont get the fact that the subaru was wrapped around a pole. and by the status of your comment, im guessing your mouth is too.
Vehicle: 1997 Honda Civic EX
Exterior: 55w 5k Headlights and 35w 3k JDM Fogs. Lowered. Sittin on steelies right now
Amplifiers: Rockford Fosgate P450.4
Batteries: Kinetik HC 800
Electrical: Big 3 in 1/0
Enclosure: n/a : (
Headunit: Clarion VZ409
Mids/Highs: Pheonix Gold Rsd6.5's in the Front Doors
Subwoofers: n/a : (
Wire: Knukoncepts 1/0 and 4g
Future Upgrades: 20% tint all around, GC/Koni coilovers, body work (fml) lol
