I made a 4th order bandpass a few months ago, and ended up blowing the sub an hour after its maiden voyage...
Here's the build from the beginning
Edited by alman101
And heres the next victim...
And now heres the finished product with a little problem...
Edited by alman101
Dude...you posted this months ago?
I know it got deleted and now I need help with a problem
Edited by alman101
Sounds like the subs bottoming out.
Its not, it sounds the same with the gian at 1/2. I think its my port but I'm not 100% sure
And if someone knows how to embed the video that would be great. I cant get it to work
Look at the coil former on the blown sub and you'll see its bent from slamming itself on the bottom and your hearing metal to metal contact in there in your video. The sub is unloading and going to ruin this sub if you keep playing with it in there.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
put the youtube url in [ youtube]
with no spaces
“He has all the virtues I dislike and none of the vices I admire.”
Winston Churchill
one thing i remember from your other thread was your sealed part was to big
and the ported is tuned to 30 hz which means your probibably tuned low low low
re tune the port closer to 60 hz and you'll notice a difference
edit
after watching video that sounds like shit you need work on enclosure more before you blow another sub
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
edit
ok thanks for the info, i will take out the port today and cut it down a few inches, its a 9inch PVC pipe, ya i know ghetto
Edited by alman101
