you can mix them, just need to swap some wires around.
The ones that would be inverted would need their wires swapped.
This is WRONG. You do NOT need to invert the wiring on any of your subs. If all 4 subs are facing the same way, then they should all be wired the same. The ONLY time you would swap the wiring on the subs is if you (for example) had 2 facing in and 2 facing out. In this case, you would swap the wiring around on the two facing in so that all 4 subs would be in phase with each other (they move in the same direction at the same time). As you have it now, all 4 subs are the same way, so don't change any wiring.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
you kinda said the same exact thing he did.
Start out boxy, shape as you move along.
Dc Audio
Team Fur
I must've read it wrong then. I thought he was saying that you could just mix and match out of phase and in-phase subs without inverting them. Lol it's 2:30 in the morning. Get off my back :ph34r:
wtf is lolcats?
yes, just swap + and - at the amp if you dont have a 180 switch on the amp or option on the HU.
Hammerdown... 1%
I love the way subs look inverted, I just HATE seeing the wires
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
make a split basket and bolt the wires to the mounting ring ;)
Hammerdown... 1%
Yep you read it wrong :P I meant if you have 2 in 2 out you need to swap the wires on the 2 out ones over, like you said :)
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
I would not do it!
The subs do look sexy, but subs don't like dust, water, ...
Be careful if you do it. You don't want to damage anything on those DC's'
I've never saw any inverted subs in pro audio or hi fi installs.
Inverted subs : looks like ghetto installs!!!
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
I would not do it!
wow, really? ever been to a car show or opened up a magazine? i see a good portion of them with inverted subs...
Team DC
  • Who's Online   0 Members, 0 Anonymous, 1613 Guests (See full list)
