Hotdog Posted April 4, 2010 Report Posted April 4, 2010 As the title said.. I just got one off eBay brand new at a very good price. Has anyone had this model before if so let me know you experience with it. When I get it and installed it will be in my build log so check that out in about a week and a half Specs * MP3 Playback via CD-R With File Names & Folder Management * Audio Video Switcher * Auxillary Inputs * Front/Rear/Sub Preouts With 80hz Low Pass Filter * 5 Volt Low Impedance Preouts * Copper Chassis! * RDS (RADIO DATA SYSTEM) Tuner * motorized, detachable fold-down face * multi-color display * will play audio CD-Rs and CD-RWs, including those encoded with MP3 files * disc naming; scrolls 16-character ID3 tags * 20 FM/10 AM presets with seek and scan tuning * selectable US/European tuning * CD/radio station titling (up to a total of 100 discs/stations) * source tone memory * wireless remote * CD changer controls * clock * 25 watts RMS/40 watts peak x 4 channels * CD frequency response 20-20,000 Hz * CD signal-to-noise ratio 90 dB * FM sensitivity 10 dBf * 1-year warranty MP3 Playback: This unit will play MP3 files that have been recorded onto CD-R or CD-RW discs using the ISO 9660 format. The RFX9300 is compatible with bit rates from 32kbps to 320kbps. The following functions are available during MP3 playback: * Folder Skip: forward and reverse * File Skip: forward and reverse * Audible File Search: forward and reverse * Random Play: allows you to play the files on the disc in random order * Repeat Play: allows you to repeat the current file * Pause: allows you to pause playback Copper Plated Chassis: The chassis is plated in copper to help shield the unit from noise. Motorized Faceplate: The faceplate on this unit shifts downward and outward to insert/eject CDs. Contrast Adjustment: The display contrast may be adjusted from -5 to +40 for optimum readability. Display Dimming: When the dimmer wire of this unit is connected to the headlamp circuit of your vehicle, and you turn your lights on, the display will dim to a preset level. The display brightness is not affected by the vehicle's dimmer control. Mounting Angles: This unit may be installed at any angle between 20-degrees above horizontal and 20-degrees below horizontal. Digital to Analog Conversion: This unit is equipped with dual 1-bit digital to analog converters. Source Tone Memory: Individual bass and treble settings are memorized for the tuner and built-in CD player. Bass and treble settings are also memorized for a CD changer, when an optional CD changer is connected. The same setting is held in memory for all tuner bands (the bass and treble settings in memory for the FM bands is also the setting in memory for the AM bands). Punch Loudness Boost: This function boosts the bass and treble response at all volume levels. Station/Disc Title Memory: Titles, up to 10 characters long, can be stored and recalled from memory for up to 100 (total) AM/FM stations or CDs. Titles cannot be entered into memory for CDs in an optional CD changer. Title memory is only for CDs played in the built-in CD player and radio stations. Switchable Tuning Spacing: The AM and FM tuning spacing may be set for US standard spacing (0.2MHz for FM and 10kHz for AM) or European tuning spacing (0.05MHz for FM and 9kHz for AM). In US standard spacing, the FM tuning range is 87.5 to 107.9MHz, and the AM tuning range is 530 to 1710kHz. In European spacing, the FM tuning range is 87.5 to 108MHz, and the AM tuning range is 522 to 1620kHz. CD Pause: CD playback may be paused without shutting off the unit. Summed Preamp Outputs: In addition to the front and rear preamp outputs, this unit has a set of summed preamp outputs. The summed outputs provide a summed left-plus-right mono output through two female RCA connections. The summed output is meant for connecting a subwoofer amplifier. For convenient level matching with the rest of the system, the summed output level may be independently set from 0 to 30. In addition, the outputs have a selectable low-pass filter, allowing you to choose 80Hz or full-range operation. Auxiliary Inputs: Two sets of female RCA jacks are provided to allow the connection of portable audio sources. Just connect your portable cassette, MD or MP3 player to this unit, and you can listen to the audio from the portable player through the speakers in your mobile audio system. Each Aux input level is adjustable and can be set to -6, 0, or +6. The jacks are located on the 10" long preamp input and output wiring harness, which connects to the back of the unit. Setup Options: * DX/Local: allows you to choose DX or Local. The DX setting adjusts the sensitivity of the tuner for rural conditions where there are weak radio stations. The Local setting adjusts the sensitivity for city conditions where there are several strong radio stations. * Americas/(Eur/Aust): allows you to select US standard or European tuning spacing * P. Play/EJ Mute: allows you to choose P. Play or EJ Mute. The P. Play setting automatically plays the tuner after you eject a CD. The EJ Mute setting automatically mutes the tuner after you eject a CD. * (V/Bar On)/(V/Bar Off): allows you to turn the volume bar On or Off * INI Volume: allows you adjust the initial turn-on volume from 0 to 30 * Contrast: allows you to adjust the display contrast from -5 to +40 * Flat/80Hz: allows you to choose 80Hz or full-range operation for the summed preamp outputs * Panel Auto/Panel Manu: allows you to choose Panel Auto or Panel Manu. The Panel Auto setting automatically opens and closes the motorized face when you load or eject a CD. The Panel Manu setting allows the motorized face to remain open and CDs to be manually loaded or ejected. * Aux 1 In: allows you to set the Aux input level to -6, 0, or +6 * Aux 2 In: allows you to set the Aux input level to -6, 0, or +6 Changer Controls Compatibility: This unit will control Rockford Fosgate's RFX8810 8-disc CD changer. This unit is not compatible with Rockford Fosgate's RFX8601 6-disc CD changer. Functions: * Disc Selection: using the remote control or the D-ACC button on the front panel of the unit, you can directly access the CDs in the changer. In addition, you can skip up and down through the CDs. * Track Selection: using the remote control or the T-ACC button on the front panel of the unit, you can directly access tracks. In addition, you can skip up and down through the tracks. * Track Forward/Reverse: audible forward/reverse search playback * Random Play: allows you to choose Track Random or Disc Random. When Track Random is selected, the unit plays the tracks on the selected disc in random order. When Disc Random is selected, the unit plays the tracks on all loaded discs in random order. * Track Repeat: plays the current track repeatedly * Track Scan: plays the first 10 seconds of each track on the selected disc * Pause: allows you to pause CD playback (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
C-Fizzy Posted April 4, 2010 Report Posted April 4, 2010 VERY nice looking deck. Let us know how it does when you get that bish installed. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
Coolwazabi Posted April 4, 2010 Report Posted April 4, 2010 i thought this didn't have an internal amp ???? very sexy though... curious.. what you drop on it ?
Hotdog Posted April 4, 2010 Author Report Posted April 4, 2010 i thought this didn't have an internal amp ???? very sexy though... curious.. what you drop on it ? I considered it a huge score at $110.55 shipped. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Coolwazabi Posted April 4, 2010 Report Posted April 4, 2010 I considered it a huge score at $110.55 shipped. NICE !!!! got it less than half...
Hotdog Posted April 4, 2010 Author Report Posted April 4, 2010 NICE !!!! got it less than half... In auction he said back in the day that this was a $700.00 Deck.. but I dont know... Still think I scored. With this Unit installed I will officially be 100% Fosgate check my sig (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
BanginOnABudget Posted April 4, 2010 Report Posted April 4, 2010 you need rockford bats. and a rockford alt. im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
Moti Posted April 4, 2010 Report Posted April 4, 2010 5v preouts and copper plated chassis = pure sex.
Hotdog Posted April 4, 2010 Author Report Posted April 4, 2010 you need rockford bats. and a rockford alt. hmmmm... Never seen them. I have seen Caps and I do have a 1 farad cap but not installed. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Hotdog Posted April 4, 2010 Author Report Posted April 4, 2010 5v preouts and copper plated chassis = pure sex. Exactly why I bought it.. im excited to get it. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
