I know its going to take some time but I need a place to start. I need to know if I should use the specs from jl if not then were do I get them or is their a common size to use with 12 if so, what is it.
well all I can say is get the specs form jl audio and start there and also turn them subs around man! make sure you wire the subs back to normal phase when you do.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
and going with one big port for all the subs allows you to modify that one port vs doing each port,. you can make plugs to fill the port and change the tuneing of the box quickly and easily...ie. one big ass port for spl burp and then slide in a port plug tuned mid range for bass race/ bass boxing and then after the show pull that port out and put in a port that tunes the box lower for daily driveing =D
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
great any pics
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
heres a half ass view of my port plug tunes my box down to 40hz
and heres a view without the plug which tunes the box to 64 hz
and to remove the port plug it only takes a few minutes by removeing 20 or so screws
Edited by mrwigglezdj
around what hz should I tune them
Edited by Justin
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Its going to be four
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Well I tuned my box for listening not just the lanes, so I am sitting at 36 hz now but still able to do a 150 at that frequency. You have to decide what you gonna so with it more listen-shock and awe, or hit the lanes.(typically pure competition situps sound like ass on music and are tuned upwards to 50 hz)
Scientia est Vox
Because I was going to add another set of subs on the third amp
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
