DDlincolnon22's Posted April 18, 2010 Report Posted April 18, 2010 we gotta cut the floor before anything Team Digital Devastation My on-going 9518 build
parton226 Posted April 18, 2010 Author Report Posted April 18, 2010 we gotta cut the floor before anything yeah i know right. I've been doing some figuring and i can get my ten cu.ft. of useable air space without having to go past my window line or past the back seat. The seat is still gonna come out so i can put my amps and crossovers there. Idk what the fuck to do with batterys yet though. Any ideas? parton226
DDlincolnon22's Posted April 18, 2010 Report Posted April 18, 2010 I would put the batts right in front of the box then build a battery box of some sort and do something crazy with the amps. Team Digital Devastation My on-going 9518 build
parton226 Posted April 18, 2010 Author Report Posted April 18, 2010 I would put the batts right in front of the box then build a battery box of some sort and do something crazy with the amps. yeah i was thinking about suspending the amps, but idk yet. and a batt box in front of the box would probably work well since im only running two. parton226
DDlincolnon22's Posted April 18, 2010 Report Posted April 18, 2010 I'm sure we could work something out with it. It should be pretty simple. I'll have to draw something up Team Digital Devastation My on-going 9518 build
parton226 Posted April 18, 2010 Author Report Posted April 18, 2010 Yeah, it shouldn't be to hard to get something to look good in there. We'll mess with it a while. parton226
02Blazer Posted April 29, 2010 Report Posted April 29, 2010 look into a bag on the bars set-up . put the bags on the outside of the frame . go with a wishbone set-up or a watts link . with the wishbone , you can have it on one side instead of the middle , kinda hard to explain , so the wishbone is not centered over the drive shaft . in my opinion , bags mounted behind the axle suck cause of limited lift and you have to go with 6" bags cause of the gas tank . now if you were to ditch the tank and use a fuel cell , go with a all reverse 4-link from Cando Specialties !! they are pretty sick and have good lift and will enable you to run bigger bags (Re8's , dom 2600, etc..)and to those who think that reverse link setups are not good don't know how to set them up right with the correct pinion angles ......
parton226 Posted May 3, 2010 Author Report Posted May 3, 2010 look into a bag on the bars set-up . put the bags on the outside of the frame . go with a wishbone set-up or a watts link . with the wishbone , you can have it on one side instead of the middle , kinda hard to explain , so the wishbone is not centered over the drive shaft . in my opinion , bags mounted behind the axle suck cause of limited lift and you have to go with 6" bags cause of the gas tank . now if you were to ditch the tank and use a fuel cell , go with a all reverse 4-link from Cando Specialties !! they are pretty sick and have good lift and will enable you to run bigger bags (Re8's , dom 2600, etc..)and to those who think that reverse link setups are not good don't know how to set them up right with the correct pinion angles ...... ill look into that thanks bro parton226
02Blazer Posted May 13, 2010 Report Posted May 13, 2010 a good bag setup will hold a lot of weight, more than you will put in there. You run into issues with the gas tank being in the way if you want a triangulated 4 link or if you want it to lay all the way out so look into suicide doors setup, they have the S-Series rides down to a science. A 3 link with bags on the bars or a 2 link bag on bars with a watts link would be good to look into. What are your expectations with this? what size wheels and how low do you want to lay out? The bags have to be done before the wall cause you will end up tubing your floor and wheel wells in the back if you want it low on anything bigger than 18's or 20's. as far as the gas tank being in the way , you must be thinking of the s-10 trucks , where the tank runs along the frame . blazers have the tank behind the rear axle , like a car ....
doug118 Posted May 13, 2010 Report Posted May 13, 2010 why dont you do a stock-floor bd? and idk what your goals are with lift in the rear but you could do an underslung frame that way you won't have a huge bump in the floor from the notch, just a smaller hump for the axle 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/
