You can do it that way but why would you?
Hook one + from one side to the - on the other side. Hook the other + and - to the amp
Wash, rinse, and repeat
Does this smell funny to you? Its your sister :roflmao:
the reason why i was asking is because my friend has a class A/B amp and the lowest it can be bridged at is 2 ohm... and his woofer is a 2ohm dvc sub, which he can wire it to 1 ohm or 4 ohm... the amp cant handle 1ohm and at 4ohm it only puts out 250 rms. so he asked me if it would be better to just hook up one side (coil) and run the one coil at 2ohm...
Run each coil on each channel instead of bridging.
EDIT: most multi channel amps run 4ohm/2ohm per channel and 4ohm bridged
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
wouldnt hooking each channel up to a each coil be the same as bridging the amp and wiring sub to 4ohm's??
he has a soundstream T5 12 (900 rms) and a rockford p5002. How would he wire it to be the loudest it can be with that amp...
you dont want to do that. if there is more sound coming from the left side of the rcas (the song fades left and right) than the right side, the voice coils will fight eachother and its not safe for the woofer.
just bridge the amp in series. safest way to do it.
ok so you guys recommend wiring it to 4ohm. but what if he just runs a + and - from one side of the woofers terminals and bridges it to the amp? and what ohm load would that be? and yes D2 woofer..
and since it has two terminals on the woofer it has two coils... they arnt connected so wouldnt it be just like a single voice coil sub? and if it was done like that what ohm load would the single coil be ran at?
Edited by dirtboi22
