CCA (copper clad aluminum) worth getting? its pretty cheap. i can get 20 feet for about $40 for 0 gauge. im planning to use it on the big 3 and 1 run from the battery to the amps. and plus im low on money right now. i mean what would be the major differences with 100% copper/high quality wire and CCA wire? thank you.
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
Cca only flows like 2000 watts or something like that versus ofc which does 3000+ my number probably aren't exact but its that kind of difference. I recommend saving for 20ft of knu fleks. Its fairly cheap and great wire.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
The knu KLMX wire is pretty good unless you are trying to pull over 260 amps, which is what the 1/0 is rated for.
well i got a hcca-d2400; it has 0 gauge inputs, and pulls 120 amps. but right now i only for 4 gauge.
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
If you're going to keep the amp, then you could use the CCA, you will not see a difference with that amp.
But if you are going to upgrade, then buy the 99.9% copper.(i know it's hard to keep on saving, but it's worth it.)
alright cool thanks. why is that though... you think this amp aint all that or what?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
Being 1200w i don't see it pulling over 120 amps.
So it doesn't really matters if you have CCA or pure copper.
The resistance is a bit more, but with that "low" wattage, CCA is good enough.
but u think this amp puts out the rated power?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
The 2 amps you're running aren't gonna pull that many amps, so the CCA knu wire is great for your application, but If you plan on upgrading soon I would get the OFC knu fleks because its rated at 300+ amps.
edit: with good voltage that amp is doing more than rated.
Edited by JPagan
