hey guys.. i want some input on this subject.. i have a single 15 that i will be using for the street b class
i will be building a burp box and was wondering what would be the best way to go about this..
heres the car..
now.. the way i was thinking was sub facing forward on the passenger side.. in line with the meter and the port out the side facing the rear drivers quarter panel.. the sub has a straight shot to the meter with the front seat reclined.. yes it reclines almost horizontal.
heres the box i had in mind. 3.4 cubes tuned to 48.7 hz
or would i be better off doing a different design..
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
i havent had much luck finding anything bigger than 4 inch pvc and i dont have the skills to router out the rings to build a wood port
and with the square i can build bolt in exchangeable ports.. :yahoo:
Edited by chewie
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
You don't always need PVC though. You could use sonotube for bigger diameters. The design sounds good though. I say try metering with different orientations.
Any reason you chose 48.7hZ? My method has been shaving 1/2" off at a time and remetering peaks with sweeps at 1/2 volume until I found the highest regardless of the frequency.
Need an install? Hit me up.
[email protected]
neo.. i chose 48 because i figured this car would peak around 50 or so..
neo ygpm
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
sonotube lol
Sonotube is the shit. Just dont let it get wet, It will fall apart. Putting a layer of fiberglass over and in it would be a good idea if you go that rout.
Ask a plumber in your area the name of the major materials supplier near you. Home depot type stores only carry a fraction of the available sizes you can purchase. They will have or be able to get bigger sizes of PVC for sure. If you want something lighter than schedule 40 ask if you can purchase foam core PVC. Much lighter and easier to cut.
A rectangle or square port would work well but a round one will look perty.
I havent messed with these kinds of boxes so I cant comment on the design. Most of the boxes I have seen in hatchbacks are sub up though. Spin the box 360 deg to see where it meters better.
im sure you can get some 6 inch aero ports online somewhere..i seen them just gotta look and see if i can find them again
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 2132 Guests (See full list)
