i have a memphis c3 dual 2 ohm 15 sub with an us xterminator 1600.2 amp when i run it bridged the amp blows the fuses ? any idea what i can do ? no shorts in the wiring doesn't blow when not briged but doesn't give enough power ? any suggestions, could it be it drops my voltage to much ?
How are you wiring it?
if your dropping the load to 1 ohm then thats obviously wayyyyyyyy too low.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
How is the sub wired? 1 or 4 ohms? if 1 ohms is the amp stable with a 1 ohm load?
Did you tune the amp gains with a DMM?
BluX
2001 Ford Explorer Sport
  • Mach 5 MJ-18 (4 Ohm)
  • Alpine MRP-M1000
  • Alpine 9813
this amplifier is 1600 watts @ 2ohm your wiring the ohm load too low for it causing it to overload or whatever the term is for it.
http://www.stevemeadedesigns.com/board/topic/33571-us-amps-xterminator-xt-16002/
his amps not 1ohm stable
So I just looked up that amp and they report...
250 x 2 @ 4 ohms
500 x 2 @ 2 ohms
1000 x 1 @ 4 ohms
So you would want to run it bridged @ 4 ohms however the question is, if this is how you are trying to run it, do you have it wired properly?
Wire it to a 4ohm load. Almost every 2 channel amp i have ever seen only runs at 4ohms bridged.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 1803 Guests (See full list)
