Its a Massive brand, it was posted up on SMD a few times. I know its in the 2k price range
But its the dual coil, dual gap design, spider on the bottom
The electromagnetic concept isn't that good, thats why it was used long time ago
There is 2 ways to do this, and either way is impractical
1 VC outside a smaller vc, tight gap, the coil on the outside doesn't move, but receives the opposite current the moving coil receives
This would be inefficient, this way, you would probably have a subwoofer that has a eff of like 70-75db 1 watt 1 meter
and then need twice as much power as any other woofer to get to be even usable really
Then you have the actual electromagnet concept
Say you have 120v going to the electromagnet, then 2000watts going to the voice coil
well, it would work, but imagine all the power supplies running to just get a coil to move, wattage, plus voltage, amplifiers, plus power converters
Has anyone ever made a DC lvl5 sized magnet out of neodymium iron boron magnets? This ferrite stuff (Iron and ceramic or something like that) is old and boring, and cheap. If no one has, how much would it cost to do so?
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
OVER 9000!
I found this quote of the Adire audio parthenon very intresting...
"A single driver existed that could displace the same amount of air as thirteen JL Audio 13W7's"
And damn the Parthenon, looks really sexy and with a xmax of 72mm it is just insane.
if the voice coil moves due to the magnetic field changing (based on the magnet) what if the voice coil were not an electromagnet and the magnet were an electromagnet and it was energized to move the coil up and down?
Heck yeah, it's amazing, especially with a rear excursion limit of 173mm (or 100 and something) and theoretically unlimited forwards excursion! Lets get some magnets from http://unitednuclear.com/index.php?main_page=index&cPath=70_71 and make one!
Be careful with neo's... if you have two the size of the palm of your hand and roughly 1" thick they have capability to crush your hand...
Thanks on identifying that, Forevrbumpn, now just gotta find better pictures of it.
Hammerdown... 1%
Yeah, I know how lethal they are, you'd probably have to shield the magnet otherwise it would kill people/break lots of stuff.
Still, someone needs to try it..
as long as you kept thick metal objects 10 feet away you'd be fine (need thickness or your magnetism is weak).
I'm sure it would get good pull to the frame of the car though lol ;)
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 2090 Guests (See full list)
