how did steve do his sub mid?
CNF Kevosinn
how did steve use the sub in his door for mid bass? I have 2 dd 1508's an I want to do a similar set up in my doors.
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
1st you need to find out if your 1508's have the frequency response needed to pull off such an idea.
The only 2 things you can do is to talk to the manufacture about the 1508 and what can it play frequency wise and the other thing is to build a box and play it full range or crossed over high pass at 60 or 80 hertz and listen for your self to figure out if it sounds good enough.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
It's true. Not just any 8" sub will work as an effective midbass. You can play with some "enclosure" sizes sealed in the door to change your response, but I would rather buy one specifically for it.
Need an install? Hit me up.
[email protected]
i think mine picks up at 55 and drops off at 250 or something like that. They are bandpassed with the 3sixty.2.
Follow my Tweet (Twitter)
thanks steve, I have a 360.2 on order so I guess ill just try them out and see what it does. do you have a box inside your door for yours?
Skyhigh wire
some batteries
  • Who's Online   0 Members, 0 Anonymous, 1409 Guests (See full list)
