BeachJoshua Posted May 8, 2010 Report Posted May 8, 2010 Anyone seen or heard of this before? My friend just said something about it... | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
Neo_frog Posted May 8, 2010 Report Posted May 8, 2010 I know some guys on here were trying it a while back, but I never heard any results. It's not impossible, but would be very difficult to accomplish. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
chapo123 Posted May 8, 2010 Report Posted May 8, 2010 ?? nope Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
abaddon Posted May 8, 2010 Report Posted May 8, 2010 Would be pretty crazy and pretty expensive. 2003 Ford Crown Victoria P71 2 12" Kicker CVX's Audiopipe AP15001d Stinger SR80 Isolator with DieHard 1200CCA battery Streetwires 0awg Secondary - 1998 Ford Expedition XLT
thebiggmann12 Posted May 8, 2010 Report Posted May 8, 2010 didn't bazooka make some that were "liquid cooled"?
HHR Ed Posted May 8, 2010 Report Posted May 8, 2010 Yeah, Bazooka did this back in 2000-2003 I believe. They had amps too. And they were supplying Prestone Antifreeze with their system. May have worked OK, but there was no real need. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
STEvil Posted May 8, 2010 Report Posted May 8, 2010 Orion XTR's were ferrofluid cooled. I havent looked it up to see how it supposedly works, but off the top of my head I dont understand it at all. The coil is the hot part and it needs to be as light as possible.. if you add water/ferrofluid/etc you may as well just make it out of thicker wire or bigger around. edit - did more reading on a whim.. interesting: http://www.ferrotec.com/products/ferrofluid/audio/audioSelect/ edit - I dont understand how water cooling would work (well, actually I have an idea on how to do it for high power burps and maybe racing.....). MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
EclipseChris Posted May 8, 2010 Report Posted May 8, 2010 If i were to do it, which in the future i may decide to, i would simply get some copper tubing and rout into the box and have it wrap around the area that the magnet meets the basket. Then have ac lines going through it, by having fittings on the ends of the tubing just protruding the enclosure. I think this could work, but i'm 17 what do i know? i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
STEvil Posted May 11, 2010 Report Posted May 11, 2010 not enough MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
HHR Ed Posted May 11, 2010 Report Posted May 11, 2010 If i were to do it, which in the future i may decide to, i would simply get some copper tubing and rout into the box and have it wrap around the area that the magnet meets the basket. Then have ac lines going through it, by having fittings on the ends of the tubing just protruding the enclosure. I think this could work, but i'm 17 what do i know? That wouldnt create a useful cooling effect. You would have to pump cooled water directly into the pole piece and top plate. You could machine out channels in the motor and tap a fitting into it that connects to a hose to carry water. Pretty much like bazooka did, then use a liquid cooling system from a computer. Or Just spray it with NOS. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
