tristan560 Posted May 10, 2010 Report Posted May 10, 2010 Just keep adding batteries then. <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
Neo_frog Posted May 10, 2010 Report Posted May 10, 2010 what if your looking for 14+volts? Then get 14V batteries. Alternators have very little to do with loaded voltage unless your current supply exceeds the demand. Just because you regulate at 14+ doesn't mean you'll see it on a load. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
CNF Kevosinn Posted May 10, 2010 Report Posted May 10, 2010 do the big 3, get a nice batt up front, 2 runs of 1/0 to the back and a second batt as big as you can get in the back. this is all stuff you would want to do with an upgraded alt so if you need to get the bigger alt or want to upgrade in the future this gives you a head start *** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ ) "kevosinn's" astro van 8 custom Sundown Zv4 18's 4 Sundown scv 6000's CNF Distribution CNC parts Skyhigh wire some batteries SMD Meters and tools used on the installhttp://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/ 16,000 watt walled silverado build.http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/ 8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60TEAM CNF Distribution
Boon Posted May 10, 2010 Report Posted May 10, 2010 what if your looking for 14+volts? Then you're shit out of luck, unless you want to spend more on your electrical than your system's worth. A 300A alt would keep you at 14+ with 2500wrms of output. Maybe. 10.x volts fo' life!
fecupe2001 Posted May 10, 2010 Report Posted May 10, 2010 Depends also on the stock alternator, the smaller it is then the car need less current to work all it´s functions, my stock alt was 70 amps, i only got a 140 amps alternator with 2 batteries and i didn´t drop below 13 volts at the amplifier If your stock alt it´s something like 60 amps, then with 3000 watts and a couple of batteries, i would say 160 is more than enough!! On the other hand, if the stock it´s something like 140 amps, then yes, i would get around 180 or 200 amps with a couple of batteries and big3 I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Flint_810 Posted May 10, 2010 Author Report Posted May 10, 2010 watts/volts=amps. use this formula to calculate. typical car draws about 30 amps so be sure to add that in. and congrats on the btl 18! i'd appreciate it man but i watin on an 15" tho [color="#2E8B57"]size="4"]1998 buick century stock elcetrical for now pioneer 3100 avh dvd HU (12)power acoustik tweeters (1) PA BAMF 5500 (1) FI 15" BTL HEAVY SUB!!! (1) kenwood 720 4cahnnel amp on da way (1) 20ft run of rockford fosgate 1/0awg (2) 1/0awg to 4awg reducers (2) memphis front speakers (2) kenwwods 69ie 6x9's (1) deep cycle batt on the way (1) 5cft box tuned to 32hz after displacments ALOT MORE UPGRADES TO COME!!!!![/size][/color]
Flint_810 Posted May 10, 2010 Author Report Posted May 10, 2010 I have the same size system with a 200amp alt and three batts, works great. so you got two batts on your BTL? [color="#2E8B57"]size="4"]1998 buick century stock elcetrical for now pioneer 3100 avh dvd HU (12)power acoustik tweeters (1) PA BAMF 5500 (1) FI 15" BTL HEAVY SUB!!! (1) kenwood 720 4cahnnel amp on da way (1) 20ft run of rockford fosgate 1/0awg (2) 1/0awg to 4awg reducers (2) memphis front speakers (2) kenwwods 69ie 6x9's (1) deep cycle batt on the way (1) 5cft box tuned to 32hz after displacments ALOT MORE UPGRADES TO COME!!!!![/size][/color]
Flint_810 Posted May 10, 2010 Author Report Posted May 10, 2010 I've ran 5k off of my 250 amp alty...just gvrab yourself a decent 200ish amp alt and a big battery and you'll be fine. Btw, I grew up in flint. Went to southwestern '03-05. str8 up man dats whats up where you move to? [color="#2E8B57"]size="4"]1998 buick century stock elcetrical for now pioneer 3100 avh dvd HU (12)power acoustik tweeters (1) PA BAMF 5500 (1) FI 15" BTL HEAVY SUB!!! (1) kenwood 720 4cahnnel amp on da way (1) 20ft run of rockford fosgate 1/0awg (2) 1/0awg to 4awg reducers (2) memphis front speakers (2) kenwwods 69ie 6x9's (1) deep cycle batt on the way (1) 5cft box tuned to 32hz after displacments ALOT MORE UPGRADES TO COME!!!!![/size][/color]
Flint_810 Posted May 10, 2010 Author Report Posted May 10, 2010 do the big 3, get a nice batt up front, 2 runs of 1/0 to the back and a second batt as big as you can get in the back. this is all stuff you would want to do with an upgraded alt so if you need to get the bigger alt or want to upgrade in the future this gives you a head start oh yea that makes sense will do man thanks!!! [color="#2E8B57"]size="4"]1998 buick century stock elcetrical for now pioneer 3100 avh dvd HU (12)power acoustik tweeters (1) PA BAMF 5500 (1) FI 15" BTL HEAVY SUB!!! (1) kenwood 720 4cahnnel amp on da way (1) 20ft run of rockford fosgate 1/0awg (2) 1/0awg to 4awg reducers (2) memphis front speakers (2) kenwwods 69ie 6x9's (1) deep cycle batt on the way (1) 5cft box tuned to 32hz after displacments ALOT MORE UPGRADES TO COME!!!!![/size][/color]
Sactownbully84 Posted May 10, 2010 Report Posted May 10, 2010 id get at least a 260amp alt i have a DC POWER 260SP and im running a SS xxx4000d on one 18" BTL loaded @ .7ohm and i never drop under 13.5 unless im idle and wangin the hell out the volume but then it goes to 13 at lowest., get a awesome alt then you wont need a bunch of batts takin up space. 2001 Grand AM Pioneer UB4000 HU Tsunami / Monster Wire's DC POWER INC 260SP ALT w/ XS Power VCM BIG 3 All 1/0 Monster 400 + YT Under Hood Stinger SPV70 x2 in Trunk 4x SA-10's On There Way soon i hope SS XXX-4000D @ .7ohm 3K+ RF Power 4x6's & 6x9's Monsoon Powered PG TL22 Line Driver 148.7db @ 35-45hz sweep w/ 12" BTL
