Hey everyone! Im new to this forum(as you can tell i have 0 posts =) ) and i already have a few questions. Im going to be getting a Audioque aq1200D amplifier. For the wiring, should i get 1/0 gauge wire or 4 gauge wire? And it says that it has 3x40 amp fuses (linked with 240) what does "linked with 240" mean? Also for the fuse holder in the wiring, should i get a 120amp fuse holder or a 240 amp fuse holder? THANKS!
Linked means using 2 amps working together, nothing you need to be worried about with only 1 amp.
As far as which wire you need, it depends on how far you're gonna run it. I'm sure someone can reply with the chart that shows how much amperage wire is capable of over certain distances.
edit: 4 gauge would be fine for under 20 feet with 120ampers running through it.. if you're getting close to the 20 foot mark though, go ahead and jump up to 2g or 1/0
Edited by sanitarium
1/0 wire is always a good idea.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
WOW! Such fast reply's! Thanks for the help! now i understand 240amp linked! Also, is this amp good for a fi bl 15"? THANKS!
thanks! i was hoping people said 4 gauge! Only because it's cheaper =) but i might get 1/0 gauge wire for upgrading the big 3 =)
i would run 0. you would be fine weith 4 but the amp has 0 guage inputs so you may as well use them. overkill never hurt and youm ight want to upgrade later. this way you dont have to re-run the power wire if you get a bigger amp down the road
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Ok thanks! how much does a 0 gauge wiring kit cost?
shop around, check audiosavings.com they're fairly new partners to smd but they have some good deals and great customer service
New Project
[top secret]
  • Who's Online   0 Members, 0 Anonymous, 906 Guests (See full list)
