IH8PunkRok Posted May 11, 2010 Report Share Posted May 11, 2010 here is an idea i had to be cheap psu's have two outputs that are +12v and it is possible to get a decent amount of amperage from one fairly cheap so... is there anything horribly wrong with hooking the 12v sources up to a car amp? just thinking and couldnt think of a better place to ask than here Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
Big Lo Posted May 11, 2010 Report Share Posted May 11, 2010 (edited) here is an idea i had to be cheap psu's have two outputs that are +12v and it is possible to get a decent amount of amperage from one fairly cheap so... is there anything horribly wrong with hooking the 12v sources up to a car amp? just thinking and couldnt think of a better place to ask than here You can hook it up but can't turn it up too much depending on PSU and amplifier Edited May 11, 2010 by Big Lo Quote Link to comment Share on other sites More sharing options...
97SSBlazer Posted May 11, 2010 Report Share Posted May 11, 2010 Any good PSU will have the Amp rating of the Rail(s) on the side. A good PSU can put out ~30 Amps per rail so you might be able to CAREFULLY power a smaller amp. I would recommend a 12V car battery with a little charger on it, that how we do our test bench in my shop Quote lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/ Link to comment Share on other sites More sharing options...
dugee81 Posted May 11, 2010 Report Share Posted May 11, 2010 you can connect it that way, i did it for awhile to just play with speakers in my room. made a cardboard vented box for a $7 8" i bought lol. youll want to just connect all of the power wires and grounds to one amp though, so it can get all the power it needs. it depends on what PSU you buy, you could buy a 500 watt PSU that would produce around 50 amps of current. the voltage usually sticks around 11.50~ or so when playing music. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
jeyrapboy Posted May 11, 2010 Report Share Posted May 11, 2010 I have a buddy that did it with psu's but there wasnt enough power to power a 200 watt amp with 3 linked together. So he wound up using like 97SSBlazer said and hooked up a 12v batt to a charger and did it that route. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2010 Report Share Posted May 11, 2010 if you use ALL the 12v leads in a PSU i dont see why you cant power a 300-400w amplifier. hell you can daisy chain PSU's by hooking them up to the amplifier (not twisting + and - together and shit, just all the yellow wires to the + on amp and same amount of black wires that are next to yellow wires to - on amp) Quote Link to comment Share on other sites More sharing options...
BulletInjection Posted May 11, 2010 Report Share Posted May 11, 2010 People do it all the time, I don't know how good it can be for an amp though Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
Big Lo Posted May 11, 2010 Report Share Posted May 11, 2010 Just got to look at the amperage a PSU can provide on the +12 volt rails, add if it has multiple rails add up the values, and then look at the fuse rating on you amplifier and this will tell you if your PSU is good enough for the amp. Take a look at this: http://www.lehigh.edu/~evb209/projects/jlsubs/jlsubs.html I found that a long-ass time ago and by looking at it and like two more he has on his website I was able to hook something up in my house. What I also do is put a pair of resistors in series through the 4 volt rail (red wire) to "stabilize" the 12 volt rail, I learned it through another website but I don't know if I got a link or not. Can't remember the ohm value on the resistors but I can check tomorrow if you want. Quote Link to comment Share on other sites More sharing options...
