Quick Big 3 Question - Grounding To Alternator Bracket?
I've heard of people grounding to the alternator bracket versus going directly to the block. i was wondering if I could Ground to either one of these bolts on the bracket... it would save me a lot of time (& some money on wire) if i could use these so i figured i would ask.
As far as i know its fine. Some motors ground out on the valve cover from factory. Just remember the more the merrier and when your doing big three its very hard to spend a lot, considering amps and stuff. Hope this helps.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
I had issues finding a suitable engine block ground and used one that bolts the bracket to the engine block...
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
Lol another s series, I ran alt case to batt and haven't had an issue
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
My alt grounds through the chassis. When I upgraded to 130 I cleaned the mounts on alt and engine. Should I run wire to frame also?
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I grounded alt case to batt, batt to chassis
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
  • Who's Online   0 Members, 0 Anonymous, 1210 Guests (See full list)
