hacer la caja para mi subwofeer
hola queria saber unos consejos para armar una buena caja para un sub de 12 pulgadas de 400 watts rms doble bobina(pioneer)
descripcion: EXCELENTE SUBWOOFER MUY POTENTE.
MARCA : PIONEER.
MODELO : TS-W308D4.
POTENCIA MÀXIMA 1400 WATTS.
POTENCIA EN RMS 400 WATTS.
DIAMETRO 12" (30 cm).
SUBWOOFER SERIES CHAMPION.
SUBWOOFER DE DOBLE BOBINA MOVIL DE 2 OHMIOS.
RESPUESTA DE FRECUENCIA DE 20 Hz - 180 Hz.
SENSIBILIDAD DE 91 Db.
google translator
hi i want to know some tips to build a good case for a sub 12 inch Dual Voice Coil 400 watts rms (pioneer)
description: EXCELLENT VERY POWERFUL SUBWOOFER.
BRAND: PIONEER.
MODEL: TS-W308D4.
Maximum Power 1400 Watts.
POWER IN WATTS RMS 400.
DIAMETER 12 "(30 cm).
DUAL VOICE COIL SUBWOOFER 2 ohm.
FREQUENCY RESPONSE 20 Hz - 180 Hz
SENSITIVITY 91 Db
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
No offense but someone tell him "no habla espanol"
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
UNOS wanted tips para saber Arm A good box for a 12-inch sub hello 400 watt RMS dual coil (pioneer)
Description: Excellent SUBWOOFER VERY powerful.
BRAND: PIONEER.
MODEL: TS-W308D4.
1400 WATTS MAXIMUM POWER.
Diameter 12 "(30 cm).
SUBWOOFER Series champion.
SUBWOOFER DUAL 2 Ohm Voice Coil.
Sensitivity of 91 dB.
Gorgo, no te entienden. Yo si pero no soy alguien que te pueda ayudar con hacer un cajon para tu bocina(s).
To any SMD member, he want specs for a box that he can make for the pioneer sub he mentioned above
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
GRACIAS ...... ES TODO DIFICIL JAJA NO ENTIENDO NADA...
Sé un poco español es probable que pueda ayudarte
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
si tu queiras envias una mensaje personal yo puede tratar ayuda mas
one of you spanish speaking folks tell him if he wants to ask questions use google translator.
it is simple and allows us to at least try and communicate easily
that was what i was trying to show with my post up there^
its easy... so do it
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1398 Guests (See full list)
