sphinxbccp Posted May 19, 2010 Report Share Posted May 19, 2010 The piece of MDF is secured to the box with different screws then what holds the amp, theres also a piece of foam over the screw heads where they would make contact with the bottom of the amp, this is a QUICK paint diagram of the rest lol please let me know if its ok or what would make it better Quote Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more... Link to comment Share on other sites More sharing options...
jmitch Posted May 19, 2010 Report Share Posted May 19, 2010 rubber bushings will work also Quote I know a lil about everything so dont call me Mr. Know it All. Link to comment Share on other sites More sharing options...
77-AUDIO Posted May 19, 2010 Report Share Posted May 19, 2010 Mounting the amp to a box can suck. The box can have vibration and cause ur amp to fry... use caution Quote PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear Link to comment Share on other sites More sharing options...
sactownstang Posted May 19, 2010 Report Share Posted May 19, 2010 I think he is using caution. IF there ain't anywhere else what can ya do. Rubber bushings? Ya could help. Quote Link to comment Share on other sites More sharing options...
VaNQuisH Posted May 19, 2010 Report Share Posted May 19, 2010 wouldn't recommend but you can do it. Quote Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP Link to comment Share on other sites More sharing options...
Fennygolf Posted May 19, 2010 Report Share Posted May 19, 2010 ya i have been down that road fried many amps before someone told me what was happening but ya it go with rubber gashings it would look alot cleaner too instead of having foam stinkin out the sides Quote Link to comment Share on other sites More sharing options...
VaNQuisH Posted May 19, 2010 Report Share Posted May 19, 2010 rubber bushings FTW. Quote Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP Link to comment Share on other sites More sharing options...
kl0wn Posted May 19, 2010 Report Share Posted May 19, 2010 Also, after putting the rubber bushings under the feet of the amp, you can place some Heavy Duty Felt Strips under the "stomach" of the amp and that will help with the vibrations too. Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted May 19, 2010 Report Share Posted May 19, 2010 I think the way you are doing it is better than I see most people do it......You should be fine, unless you have an amp that is notorious for being vibration sensative I.E. DD Z1. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
sphinxbccp Posted May 19, 2010 Author Report Share Posted May 19, 2010 the foam isnt hard, and it doesnt stick out the sides Quote Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more... Link to comment Share on other sites More sharing options...
