Camp Dc Maxx Begins Again Update 8/6
I got some more work done today. I got the ports cut and the first layer of my baffle cut. I had first made the baffle one piece which took a long ass time laying everything out. So after cutting the baffle out, the hole for the port, and the sub holes I decided I would put in the ports.
Cutting the ports was no easy task either since both the top and bottom of my box slopes. After a little bit of math and engineering I finally got them where I wanted them which should make tuning around 35htz.
Well after installing the ports I tried to test fit the baffle once again to make sure everything lined up and whatya know it wont go in :( So now instead of a one piece baffle it will be in 2 pieces.
On to the pics.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
2006 SPLMAX Bass Race Competitor of the Year
2006 Bass Race 156 points
Team DC Sounds
Team Maxxsonics
Team HR
Team Second Skin
Team Hooker Audio
http://dcsoundlab.com/
2008 Starting from scratch
ah dont sweat the 2 piece baffle man My wall was built like that also and the back of it is actuall 5 pieces total from the two layers.....I had to cut them like that to get them in the burb. Looking good though!
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Guest Nismofreak
NIce coming man...can't wait to start my build...when you think you might get em subs in by?
they should be there in the next couple days I believe but like I said pm Rusty and he can help you more than I can bro.
Thanks for the comment sguys.
Tommorow I will drop the first coat of resin on the inside and try to get my other baffle cut. I want to have this thing up and playing by the end of this weekend. I wont be done but it would be nice to get some sound of it.
Team DC Sounds
Team Maxxsonics
Team HR
Team Second Skin
Team Hooker Audio
Guest Nismofreak
I meant when your gonna put your subs in for a test fit?
I hope to have everything in for a tes run by this weekend. Then its all gonna come back out when I get my carpet in.
Team DC Sounds
Team Maxxsonics
Team HR
Team Second Skin
Team Hooker Audio
i wanna see how them dc subs do.they look damn nice and beefy.
2002 nissan frontier crewcab
eclipse cd2000
mb quart prem's fr&rear
rf p4004
Well it was assholes and elbows today. I did the first coat of resin in the car because I had plenty of other stuff to accomplish after.
After the resin was done I decided I would cut my second baffle pieces. After realizing I had run out of wood it was off to the depot.
So after an hour at the depotit was back to work.
Atfer the baffles were cut I decided to tackle the trunk and try to get that organized. Made a template for the trunk floor then I cut it out of 3/4 MDF. Realizing I needed to have access to the lil spare tire I cut it in half so I could pull one piece out and access my tire.
I drilled 3 holes in the back of the bard by where the batteries are going so I could bring my wire up into the trunk. Fortunately I was able to reuse the piece of stock carpet that came out.
Well after that was done I figured hell I might as well get the wire ready for the batts. So I broke out the torch and the soldier and soldiered all my ring temrinals onto the wire. I couldn't get my wife to help so there are a couple pics of a quick little jig I made to help hold the wire while I was soldiering.
Enough rambling and onto the pics.
1st coast of resin
Posted Image
both baffles glued and screwed together.
Posted Image
the jig I made in about 10 seconds :)
Posted Image
some soldering going on
Posted Image
Posted Image
me hard at work
Posted Image
trunk with the batts loaded and wire brought up through the trunk
Posted Image
Team DC Sounds
Team Maxxsonics
Team HR
Team Second Skin
Team Hooker Audio
