I have had this thought before and I am wanting someone to try this because I don't have a barometer .. if not I will try to get one and make a video.
Anyway what I would like someone to do is to get a barometer if you have one, put it in your car and film the barometer when you turn up the bass.. lets see what your barometric pressure inside you vehicle is.
What is barometric pressure.. here is a little info.
Standard atmospheric pressure
The standard atmosphere (symbol: atm) is a unit of pressure and is defined as being equal to 101,325 Pa or 101.325 kPa. [1][2] The following units are equivalent, but only to the number of decimal places displayed: 760 mmHg (Torr), 29.92 inHg, 14.696 PSI, 1013.25 millibars. One standard atmosphere is standard pressure used for pneumatic fluid power (ISO R554), and in the aerospace (ISO 2533) and petroleum (ISO 5024) industries.
In 1999, the International Union of Pure and Applied Chemistry (IUPAC) recommended that for the purposes of specifying the properties of substances, “the standard pressure” should be defined as precisely 100 kPa (≈750.01 Torr) or 29.53 inHg rather than the 101.325 kPa value of “one standard atmosphere”.[3] This value is used as the standard pressure for the compressor and the pneumatic tool industries (ISO 2787).[4] (See also Standard temperature and pressure.) In the United States, compressed air flow is often measured in "standard cubic feet" per unit of time, where the "standard" means the equivalent quantity of moisture at standard temperature and pressure. For every 1,000 feet you ascend the atmospheric pressure decreases 4%. However, this standard atmosphere is defined slightly differently: temperature = 20 °C (68 °F), air density = 1.225 kg/m³ (0.0765 lb/cu ft), altitude = sea level, and relative humidity = 20%. In the air conditioning industry, the standard is often temperature = 0 °C (32 °F) instead. For natural gas, the petroleum industry uses a standard temperature of 60 °F (15.6 °C), pressure 101.56 kPa (14.730 psi). (airpressure)
Also look at Barotrauma -- Link
i dunno, sounds too complicated, i dont think i wanna no lmao
2000 lincoln navigator 4 Lanzar 15s (Soon to be 4 TFS Guvment Cheezes)
Team DBs (Driven By sound)
Actually really easy if you have a barometer.. just put it in the car and video tape it while you turn the bass up all the way .. will give you an idea of what the atmospheric pressure inside your vehicle is compared to what it is outside.
Won't the fact that it varies between positive and negative pressure make it impossible to get a reading? It will either fluctuate really fast, or it will stay neutral because of the average will be neutral.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
Its been tried.
I have never seen barometric pressure change in a car. Even at 160+ dB.
The rapid change from pressure to vacuum doesnt read in barometric pressure.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Its been tried.
Yus! I was right! Do I get a cookie?
Its been tried.
damn.. well thought it would be a cool experiment.
