IM a newb to the oscopes. Does unhooking the subs make a difference in what the oscope shows? or does it just make less noise? Also 0db and -5db? You dont use a tone that matches the frequency of the box?
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
Input Voltage: 200 mV - 6 Volts
Voltage goes up the more I turn up the sub output on the EQ, should I set the sub output to 6v and then reset the gains on the amp?
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
No, the signal should show the same with subs hooked or unhooked.
And 0dB and -5dB tones refers to the level at which the tone is recorded. A 0dB tone would be the loudest recording without distortion in the recording.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
If the gain sens. is at 6v, that is the lowest setting and shows the highest voltage it can take without distorting. So if you are inputting 10v, you are automatically in clipping.
Set your max signal to 6v, then test the amp.
Ed Lester
ShowtimeSPL Host
My old Build Log
Thats kinda what I was thinking also.
Will give it a shot and see what happens.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
Sorry to thread jack, but how would you know how any volts to give an amp. My line driver adjusts between 2 and 11 volts.
The amp should say, or in the manual, on the gain sensitivity adjust. Usually the lowest setting is anywhere from 5-9v, and highest is maybe 200mv.
Ed Lester
ShowtimeSPL Host
My old Build Log
