Okay so I recently bought the Viper 5701 alarm and there are a lot of wires if someone knows of a wiring diagram or of something that can help me figure it out that would be a great help.
This is going in a 2004 Ford Ranger and I have a chart that says what most of the wires are so any help would be appreciated.
EDIT: bad link heres the thing
FORD
MODEL YEAR(S)
RANGER 2004 -2006
KEY T-HARNESS IMMOBILIZER
FD KEY-4 FD-1(2004-2005) Only! FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM, Requires 791 and Extra Ignition Key
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT YELLOW (+) IGNITION SWITCH HARNESS
STARTER RED/LIGHT BLUE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 LIGHT GREEN/PURPLE (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/LIGHT GREEN (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 GRAY/YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) WHITE/BLACK (-) @ SJB, Small BLACK Plug, Pin 16, See NOTE *1
PARKING LIGHTS ( + ) BROWN (+) @ SJB, BROWN Plug, Pin 8, See NOTE *1
POWER LOCK PINK/YELLOW (TYPE B) @ SJB. LARGE BLACK Plug, Pin 5, See NOTE *1
POWER UNLOCK PINK/LIGHT GREEN (TYPE B) @ SJB, LARGE BLACK Plug, Pin 9, See NOTE *1
LOCK MOTOR WIRE RED (+) @ SJB, GRAY Plug, Pin 9, See NOTE *1
DOOR TRIGGER YELLOW/BLACK (-) and GRAY/RED (-) Use both, See NOTE *2 @ SJB, See NOTE *1 4698_Ranger_FORD DOOR PIN ISOLATION.pdf
DOMELIGHT SUPERVISION BLACK/LIGHT BLUE (+) @ SJB, GRAY Plug, Pin 14, See NOTE *1
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN YELLOW/LIGHT GREEN to DARK BLUE (-) @ SJB, SMALL BLACK Plug, Pin 18, See NOTE *1
TACH Any wire that is NOT RED @ any IGNITON COIL or FUEL INJECTORS
WAIT TO START LIGHT N/A
BRAKE LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 The SJB (Smart Junction Box) is the FUSE/RELAY BOX in the PASSENGER KICK PANEL.
NOTE *2 The YELLOW/BLACK (-) is for the DRIVERS DOOR, LARGE BLACK Plug, Pin 6 at the SJB and the GRAY/RED (-) is for the PASSENGER DOOR, SMALL BLACK Plug, Pin 3 of the SJB. When connecting to an ALARM SYSTEM use both DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
EXTRA INFORMATION
Edited by darthballsy1
Pioneer DEH-P3000IB head unit
Rockford T1000.1bd
Two AQ SDC 2.5 12s
My build log.
http://www.stevemeadedesigns.com/board/topic/84319-darthballsy1s-04-ford-ranger-video-build-log/
So do you not have the install manual?
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
If you've never done a remote start install before then you might want to consider having it done professionally. The 5701 is not a simple install as the aspect of it's many features.
There's no one going to stop you from doing the install yourself if you are that determined, but I would strongly suggest against it if you don't know the proper techniques for making connections for a remote start system. If you understand what type's of polarities your system will need as well as it looks like you will need a bypass module for your ignition. What this does is act as if the key is in the key cylinder whenever you remote start.
Like I said, it's definitely NOT a novice install.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
PM me your email address and I can email the install manual for it.
Kenwood eXcelon 995
  • Who's Online   0 Members, 0 Anonymous, 1791 Guests (See full list)
