LilTeddyP Posted May 22, 2010 Report Posted May 22, 2010 Did a quick search but couldn't find anything. I know a guy that used to fuse his grounds and I always just gave him shit and fucked with him about it, just for shits a gigs. Now I have 2 matching fuse blocks and was wondering if it is good bad or indifferent to fuse the grounds. I just want to do it to clean up the wiring. LMK Thanks! 2001 Bravada (2wd) Pewter on 24's JVC KW-AV60BT 10 Alpine Type-S 6.5s 2 PSI/BTL 18's @ 32Hz 2 Rockford Fosgate T25001-bd's @ 1-ohm each Rockford Fosgate T1000-4 Rockford Fosgate T400-4 Rockford 3Sixty.2 Yellow top up front, 2 9a31s in the back LOTS of AT 1/0 Python 991 350 Amp Singer Alt "Build Log" My Facebook My YouTube i didnt see the video or read anything but...cool story and the reason your being a cock tonight is?
dugee81 Posted May 23, 2010 Report Posted May 23, 2010 I don't think you'll need to do something like that! Just make sure your grounds are rock solid, with the grounds sanded down for a good connection. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
andym85 Posted May 23, 2010 Report Posted May 23, 2010 considering they aren't 'live' wires....no..plain and simple i likes me some audio stuff...
EricR Posted May 23, 2010 Report Posted May 23, 2010 What I want to know is what is going through your mind to make you think they should be fused? i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
wL<3bass Posted May 23, 2010 Report Posted May 23, 2010 :facepalm: Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
LilTeddyP Posted May 23, 2010 Author Report Posted May 23, 2010 It plainly states right there that I have matching fuse blocks and wanted it to be cleaned up a bit, don't be a cocksucker 2001 Bravada (2wd) Pewter on 24's JVC KW-AV60BT 10 Alpine Type-S 6.5s 2 PSI/BTL 18's @ 32Hz 2 Rockford Fosgate T25001-bd's @ 1-ohm each Rockford Fosgate T1000-4 Rockford Fosgate T400-4 Rockford 3Sixty.2 Yellow top up front, 2 9a31s in the back LOTS of AT 1/0 Python 991 350 Amp Singer Alt "Build Log" My Facebook My YouTube i didnt see the video or read anything but...cool story and the reason your being a cock tonight is?
chud Posted May 23, 2010 Report Posted May 23, 2010 It plainly states right there that I have matching fuse blocks and wanted it to be cleaned up a bit, don't be a cocksucker It also plainly says that you gave one of your friend's hell for doing the exact same thing you're now asking about. :fyi: You can't fix stupid
LilTeddyP Posted May 23, 2010 Author Report Posted May 23, 2010 It also plainly says that you gave one of your friend's hell for doing the exact same thing you're now asking about. :fyi: And it also plainly stated that is was for shits and gigs. He swore that it was fine to do and wouldnt create an issue. This is why I wanted another opinion, not to have some fucktard talk shit. My intentions were plainly stated because I don't have a distribution that matches my fuse block 2001 Bravada (2wd) Pewter on 24's JVC KW-AV60BT 10 Alpine Type-S 6.5s 2 PSI/BTL 18's @ 32Hz 2 Rockford Fosgate T25001-bd's @ 1-ohm each Rockford Fosgate T1000-4 Rockford Fosgate T400-4 Rockford 3Sixty.2 Yellow top up front, 2 9a31s in the back LOTS of AT 1/0 Python 991 350 Amp Singer Alt "Build Log" My Facebook My YouTube i didnt see the video or read anything but...cool story and the reason your being a cock tonight is?
chud Posted May 23, 2010 Report Posted May 23, 2010 And it also plainly stated that is was for shits and gigs. He swore that it was fine to do and wouldnt create an issue. This is why I wanted another opinion, not to have some fucktard talk shit. My intentions were plainly stated because I don't have a distribution that matches my fuse block Let's argue about it further. It's a very interesting and intelligent topic. Be sure to get real mad too, bro. I want to see steam shooting out of your ears... You can't fix stupid
