need help! 1998 cavalier... no spark
alright so im hopeing someone here can help me. car is a 1998 chevy cavalier 2.2 rally sport. so a while ago car wouldnt start, fuel pump wasnt turning on so i figured it went to shit. i replaced it and the car started right up, drove it for a day now it wont start again. it started jus fine for 2 starts, then when i went to start it again it didnt want to start. waited a lil bit then it started again but when it started it revved up to about 3 grand. then when i turned it off thats when it wouldnt start again. i checked to see if there was spark and there is no spark comming from any of the sparkplug wires. car has brand new ngk plugs. there is very low wattage comming from my ignition fuse (tested with a dmm at the fuse panel) the car will turn over but wont fire. if anyone could help me i would greatly greatly appreciate it. i might have missed sum stuff but if you could help me troubleshoot it that would be great. thanks in advance
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
im thinking ur alt went out, thats what im just guessing. my cavalier did the same thing it was just the alt for me. so id get it tested
Once you go loud, you never go back
Fi btl 15
pa bamf 5500
Blazer xtreme
Thats just winter system
New build coming
Check voltage at your battery. Your main relay may be the problem. it controls your spark and fuel, if its hot outside they tend to hang up in cavi's. Im not sure where its located on a 98. But sometimes if you let it sit a while it will cool down and work for a while just fine. something to think about
As far as your alt going out, very possible. If you plan to get it tested make sure where ever you get it tested to bench test it, not on the vehicle. and If you go through all the trouble to pull your alt, may pull your coils off and have them tested also, autozone and oreillys will do this for free
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
Ignition relay. Check grounds, coil, distributor cap and wires.
these cavaliers are distributerless, its all run by a computer. so there is no power going to the coil, checked it tonight with the dmm, its seeing only like .3 volts when it should have 5volts i believe. i know a little about cars, more then the average joe but i dont know everything. there is no relay for the ignition. the cap and ignition module are in the same place. anyone have any idea what is supposed to be sending power to the coil/cap? i have a feeling its the powertrain control module but i hope its not cuz that would be expensive. if anyone has any ideas please help, give me an idea ill try it
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
shit ton-o-wire
Team SMD
  • 2 months later...
yeah look on your drive side fuse panel and jump wire the pcm fuse to the pcm ign fuse you lose position one on the ignition but it works like a charm what has happened is you have prob have an open lead on your ignition switch if you look up fuel pump cavalier from 97-2000 i believe they all had this prob btw you didnt need the fuel pump either also controlled on the ignition side there all linked in a row in the fuse box so provide power to the one and the rest will work now if i only had the time to find the open lead or do the ignition switch lol anyway good luck and sorry for resurecting an old thread but tons of issues on the web with this and this seems to be a common solution to all of the also on 96 cavaliers the fuel shutoff is usually the culprit
