Mono block Amps or one Big amp?
1 amp should be cheaper then 2 amps.
Only if the single amp puts out rated and the other doesn't.
And a beefier amp will not help with clipping, it will only make it worse.
If u would connect the 1200w RMS amp to both subs, at 1 ohm, then you would get 600 w RMS per sub.
The same as one amp per subwoofer, and it's also more dangerous to use 2 amps, because the Gain must be matched.(matched perfectly, not just turn the knob till it looks "ok".)
fail again, sorry on iphone, it was auto spelled, or what ever, clipping is when your amp is gone past its limits and the speaker or driver wants more and the amp clips the signal, you obviously have NO idea what it is, a bigger amp would help....
Ugh... :orly3:
Clipping means turning perfect sine waves into "square" or "squareish" waves.
This creates a peak, and because it's a square wave heat will build up.(the cone moves and stops while still getting power.)
Clipping mostly happens when the BASS EQ is set above 0 on the HU or when you turn you're HU up so much that it's going to try to put out more Volts then it can make, thus squaring the sine waves off.
It also happens because of people who turn the BassBoost on the amp up, and not setting the gains on a amp properly.(<=this is probably what u did.)
A amp can also clip if it is provided with too low voltage.
I think you have no idea what you are talking about, and 1 1200 rms mono amp would be cheaper than 2 600 rms mono amps. And 2 amps would be harder on your electrical system
i could care less about my electrical system, i have a what....180 amp alt?
cant remember it was from out of a police car, im fine on that part and defiantly not form the research shopping i have dont
and my gains are all the way done, damn and clipping also happens when the AMP IS TRYING TO OUTPUT MORE POWER THAN IT CAN.
if i get a bigger amp then clipping will be less of a problem is i set my gains all the way down to minimal, thats what i always do.....
gains makes it to loud
If u set up the gains properly, then you would (almost never) have any clipping.(except if u do one of the other things i posted above.)
You can set you're gains with a DMM or a O-scope.(O-scope is much better, but hard to get.)
If you dont care about your electrical system then your priorities are all messed up. Ever heard of the expression "puttin' the wagon before the horse"?
Hopefully the word usage errors are due to the iPhone. BUT when I type on mine the words are fixed not encrypted into jibberish
Toyota Avalon
5% Tint
6000k HID
JVC AVX-720 HU
iPhone 3g
2 Memphis 15-MCC5 Component Sets (Front Doors)
2 Memphis 15-MC52 Coaxial (Back Doors)
1 MTX 9500 15" Dual 4 Ohm
Alpine MRP-F240 4 CH. 40 watts RMS (Doors)
MTX 8100.1
SCTD-logo.gifKobalt_-logogif.jpgMTXlogo.gifJVC-Logo-Mobile.jpgstmini_logo.jpgMidlandLogo1_250ph.jpg
Add Me On Facebook.
no matter what i do, gain bass boost or anything like that, it clips NO MATTER WHAT!
thought i go hook my bnox to my buds care, sounds amazing......
and why would i need to worry about stressing my alt WHEN ITS RATED for A GOD DAM POLICE CAR AT ALMOST 200 AMPS????
LETS SEE...
600 watt amp will generally draw 60 amps.
you want 2
60x2=120
you said its a 180 amp alt.
180-120= 60
180 amps its Revving the engine so regular driving or idle it more like 120 if that. SO...
your eating up your amperage with just your amps for bass.
Take into account your AC/ Heat and whatever else your running and it aint lookin to good.
Kinda like 10 pounds of shit in a 5 pound bag.
MAKE SENSE???
Toyota Avalon
5% Tint
6000k HID
JVC AVX-720 HU
iPhone 3g
MTX 8100.1
Add Me On Facebook.
Impossible, what is you're definition of clipping?
What kind of sound do you hear?
  • Who's Online   1 Member, 0 Anonymous, 1835 Guests (See full list)
