hi guys,
new member but been here a long time.
I have a alpine type r 12''
its 500watts rms,
i wanted to know how much power this sub can handle for a daily use,
I was looking at 700w or 1500w jbl amplifiers.
I know 1500w is alot for this sub, but i was going to turn the gain down,
Also how do u know how much rms power a amp is giving, can you measure it with a multimeter?
One last question. Are there any designs out there for a ported enclosure for this sub?
Thanks Jazz
hi guys,
its 500watts rms,
Thanks Jazz
Give it 500 watts. Don't give it more unless you know what you're doing.
Amps will usually say the RMS. If they don't, then it's probably a shitty brand.
I'm pretty sure to find watts, its your volts times amps = watts
I'm pretty sure there's designs out there, just look around or search. Building a box for a 12 is not that difficult and im sure someone here would design you one if you asked.
2006 Nissan Z Track.
My Feedback Thread
to find wattage it is voltage times current.
something like that i cant remember shit lol :P
My Feedback Thread
I Use a box that is about 1.96 cu^ft per chamber running 2 on 2000 watts rms daily. They dont get smelly At all, im feeding each one 1000 watts rms at a 1 ohm load at 14.6 volts
my 4 are set up with 2.3 cubes, per sub. 30 square inches of port, per sub, tuned to 34hz. and get about 850 rms daily.
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
Il probally be powering off one of these,
I think there the most suitable towards my budget.
http://caraudiosecurity.com/shop/product/products_id/8045.html
http://caraudiosecurity.com/shop/product/products_id/4250.html
this is the cut sheet
top: 26''x18''
bottom: 26''x18''
left side: 14.5''x16.5''
right side: 14.5''x17.25''
back: 26''x14.5''
front: 22.75''x14.5''
port mouth: 14.5''x14''
port tail:14.5''x18''
thanks to bassl0va for this.
It is tuned to 35hz
Once I minus off the port, bracing, and sub im left with 2.3 cubes.
  • Who's Online   0 Members, 0 Anonymous, 1045 Guests (See full list)
