I wanna do the same terminals as meades box
would I jus need something like quater inch stainless all thread through the box and a washer and nut to the box then the ring terminal for +/- then another box?
Will the wood cancel out and power or current?
Thanks
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
In English?
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
I used brass bolt when we used normal bolts the gave me a nasty imp rise
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
always wondered if it had a noticeable rise. The bolts don't conduct as well as stranded wire. Maybe thread some small copper bar?
That actually explain a bit.......
I went from 9 ft of 16awg to Direct 8ga and Bolts and didn't gain any db......
finally something I can do! I had surgery a month ago and I am gimped up and one handed for a while but I can thread some copper!
I am going to see if I can score some and compare the resistance against some steal and stainless bolts.
If you do use bolts, use a double nut on the outside. Then you can have one nut hold the ring terminal and the other holds the bolt in, so then you don't have to remove the subs to tighten the bolts.
1985 Chevy Silverado Black and Silver SBC 350/700r4
I need to do this sometime, using those plastic red and black connections or whatever they are, are no good. So just any kind of bolt and nut works?
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
  • Who's Online   0 Members, 0 Anonymous, 3402 Guests (See full list)
