thehoe92 Build v2 Update! 3/13 iPad install!
more bad news..
driving along today bumpin my mids and highs with the volt meter on and I watch it go up and down from 13.9v to 14.4v wondering why since its only 300 watts and it always stays solid then out of no where just drops to 13.1v :angry:
now I have to go troubleshoot and see why my back battery isn't charging
this is getting real old, real fast
Wouldnt be thehoe92 without teh purple
I would start by checking your HID's. Those ballasts could be fucking with your voltage
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
the ballast wouldn't keep my back battery from charging completely
started troubleshooting..
the way I had my 1/0 run before tonight was;
ground on the alternator block going to the frame
ground on the alternator block going to the ground of the front battery
and then my ground run to the back battery on the alternator block
positive run from the back of the alternator post to the back battery
and no positive from front battery to alt so I had like the Big 2
started by checking the fuses, not blown
made sure all the terminals were secured, they were
even went in the back and at a last ditch effort took off the negative and the positive 1/0 coming from the front and tried sparking them and nothing happened so it has to be something wrong with the positive
the way I had the power run before I ran it on the drivers side was a little 2 foot section going to the fuse block on the fuse box then another 1 to 2 foot section going from the fuse block to a battery isolator then the 16 foot run going to the back
took off the battery isolator a long time ago and just put a bolt through both terminals and secured them together with some protective tubing over it
then when I ran it to the drivers side I wanted to eliminate both terminals and the bolt because its just adding resistance
pulled off both terminals and cut the loop off of it so it was just a sleeve and then crimped it on to both wires not even thinking that I had enough to just eliminate that little 1 to 2 foot section
so I narrowed my problem down to that.. took all the electrical tape off and sure enough it wasn't even connected anymore
not a problem just take away the 1 to 2 foot section and strip back the RF 1/0 and stick it right in
then I moved the positive from the back of the alternator to the front battery and added another piece of 1/0 to connect both of those to complete the Big 3
moved the negative from the alternator block to the negative on the front battery and now all I need is a better spot on the frame for the alternator to frame and then I'm going to add another run from the frame to the negative on the front battery
also while I was by the front battery I noticed my HID's ground was right on the bar that goes across the battery and it was loose so figured out that problem
took that bolt off and sanded down that as well as the actual terminal and sanded down the alternator block to get all the dirt off
voltage is now solid at 14.8v and won't budge
and my HID's work again :)
NICE glad that you got everything working again
Wow finely some good luck :yahoo::clapping:
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
where is that "pat on back" smiley? good job bro. was hoping it was an easy fix. sorry so many problems lately. when we hanging out homie? been awhile since checking out the hoe - lol
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
oh yeah and I forgot to add the most important thing I overlooked..
the reason I had so much alternator whine was because the ground was right next to the alternator so now that its move to the front battery its almost completely gone back to where I normally had it
everything is coming along real clean inside, I've got all the wires ran neat and now I'm just waiting for the 6 15's and my amp to get back :)
matt you know the number haha I'm always just chillin working on the truck hit me up if you want to come check it out
luck has nothing to do with it, good job, next time do it the right was the first time around :D
Got carbon fiber dust cap???
bad karma?
haha its just bad in general but yeah that would be the moral of the story
just do everything right and neat the first time then you won't have to go through so many god damn zip ties because you have to undo what you just did :angry::lol:
