driver side both ports.
i do it all the time just like that
i use the psp 4" and 6" ports on my boxes great product. you will be fine with those elbows as a matter of fact i just usually go to home depot or lowes for the elbows. as far as putting both ports on the drivers side you could do that, but i don't think putting one on each side would hurt anything unless you plan on having your door open often.remember any time you open a door or window it's going to change your tunning regardless of where you put your ports. especially in the cab of a truck.
Edited by jizazz12
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
I'd do them out the front or back, more likely the back and tune slightly high so you get a 6th order effect somewhat.
should be easy to do with a couple elbows.
Hammerdown... 1%
i like this idea... regular pvc/abs elbows will work with this aero right?
http://www.parts-exp...tnumber=268-350
As long as you are using the Aero Ports from Precision Port, you can use thin wall sewer pvc fittings. It must be the thin wall stuff and they will match up perfectly. I'm using the 90 degree elbows on my 6" aero's and they work great. If in doubt, just bring one to the home depot and do a test fit.
97 Maxima SE
Bunch of shit going in, check out the build
  • Who's Online   0 Members, 0 Anonymous, 748 Guests (See full list)
