hi i was just wondering if i would be able to wire my subs witch are dual 4 ohm down to 1 ohm then into the amp is it ok to do it like this or should i wire it in the box what i mean is it ok to have 2 wires leading in the + and - on the amp thanks
Subs: 2 Dual 4 DC lvl 3 12's in ported box 34hz tune wired to 1 ohm
Hu: Eclipse 5425
Amp: Soundstream pcx1500d
because they dual 4's and hes wiring them in parallel to get a 1 ohm load. idk if that work though.
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
you can do it that way but it's better to do it inside the box helps keep things tighty and neat.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
ok thanks for the quick responses just wasent sure thanks guys
Hu: Eclipse 5425
really that would work? i would prefer to do that to avoid past problems i have had... check my latest thread LOL
ya just run one 8 gauge for hot and one for ground into your box then wire all your positives and negatines to them in parallel. beter make sure your amp can handle a 1 ohm load 1st thow
ok thanks again
Hu: Eclipse 5425
