Relyks Posted June 22, 2010 Report Posted June 22, 2010 Does anyone know where i can get this white sound i heard this is best way to adjust ur gain on your amp by getting white sound turning it all the way up and using meter read wat it is putting out should be like 28.3 if anyone know wher ei can download and burn this sound please tell me (: --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Slawsen Posted June 22, 2010 Report Posted June 22, 2010 More than likely from Realm of Excursion...same place you get every other tone, lol. 00' Nissan Xterra Always under construction :] HU: Pioneer DEH3100-UB Mids & Highs: Kicker DS Component Set & Crescendo tweeters Mids & Highs Amp: Rockford 150.2 Subwoofer: 2 DC Audio LV 4 18"s Subwoofer Amp: Hifonics Brutus 2005d you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
bumpnthump05 Posted June 22, 2010 Report Posted June 22, 2010 Does anyone know where i can get this white sound i heard this is best way to adjust ur gain on your amp by getting white sound turning it all the way up and using meter read wat it is putting out should be like 28.3 if anyone know wher ei can download and burn this sound please tell me (: Realm Of Excursion Downloads Loud & Proud 1995 Honda Civic Head: Pioneer AVIC-F700BT Front Stage: 6.5" Pioneer Cheapo's Rear Stage: 6.5" Pioneer Cheapo's Subs: (1) Audioque HDC3 10" (3.0cu ft) Tuned To 30hz Sub Amp: Audioque AQ3500D Wiring: Phoenix Gold 4 gauge & Rockford Fosgate Circuit Breaker Electrical: Stock Alt, Stock Battery (Front) & Optima Blue Top (Trunk) OLD SPL IN CAMRY = 143.5db LEGAL @37hz (6/12/10)
Relyks Posted June 22, 2010 Author Report Posted June 22, 2010 Thanks alot and hey im only 17 im learning (: only been looking into systems for couple months now . --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Slawsen Posted June 22, 2010 Report Posted June 22, 2010 Thanks alot and hey im only 17 im learning (: only been looking into systems for couple months now . Though I am curious as to whether or not that method actually works..i'd still go the DMM route.. 00' Nissan Xterra Always under construction :] HU: Pioneer DEH3100-UB Mids & Highs: Kicker DS Component Set & Crescendo tweeters Mids & Highs Amp: Rockford 150.2 Subwoofer: 2 DC Audio LV 4 18"s Subwoofer Amp: Hifonics Brutus 2005d you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
J-Lane Posted June 22, 2010 Report Posted June 22, 2010 Your best bet is to use a scope and a sine wave @ 0 dB.
Relyks Posted June 22, 2010 Author Report Posted June 22, 2010 maybe if i owned that or a audio shop but seeing how im 17 and dont own either then this is next best way (: --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Forevrbumpn Posted June 22, 2010 Report Posted June 22, 2010 White noise is what you play through a sound system, when you have a RTA available, to fine tune a sound system to get your system as flat as possible or to adjust it as wanted white noise plays all sound from 20hz - 20khz, and ends up sounding just like static, like a tv on a station that doesnt come in at all you will need some damn good ears to fine tune this way I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
kirill007 Posted June 22, 2010 Report Posted June 22, 2010 White noise is what you play through a sound system, when you have a RTA available, to fine tune a sound system to get your system as flat as possible or to adjust it as wanted white noise plays all sound from 20hz - 20khz, and ends up sounding just like static, like a tv on a station that doesnt come in at all you will need some damn good ears to fine tune this way Good ears? He said he is going to use a meter, probably a DMM. Thinking is the root of all problems... You ALWAYS get what you pay for.
