Im confused on how so many people can think that under powering can damage subs. Cause if this was true every time you turn the volume down it would blow your subs right?
Yes me to hints the reason i made this thread, maybe it was something i misunderstood... But its clear you blow a sub due to dirty clipped power in this case..
Maybe a mod can clean up the unneeded stuff and make this a sticky for ppl in the future wanting this answered....
Edited by orangecounty
2002 civic
2- 12in dc lvl5s
1- crescendo 3kwp ( 1 more on the way)
1- stock honda alt
4-xs d3100s
3-asa300.2 amps
6- PB 4XL's
4-PB l-3h tweets
and a bunch of other sh!t
the build
http://www.stevemeadedesigns.com/board/topic/74044-project-will-it-fit/
Youtube channel
http://www.youtube.com/user/slammedblackbish
Volume does not = power being produced. Amp always makes the same amount of power. As said by others, amps are stupid, they don't know what to do so they just keep making a set amount of power depending on voltage, impedance, and gains. The amp doesn't say "OH HAI HE'S TURNING THE VOLUME DOWN, I'LL BE SURE TO CREATE LESS POWER"...
Edit: If you meant "....time you turn the GAIN down..", then you are correct. If not, read the above.
clean power VS. dirty power
Dirty power? You mean signal? No such thing as "dirty" power..
Edited by Slawsen
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
:orly3:
1. amps do not always make the same amount of power
2. there is such a thing as dirty power, after all signal is power
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
x2
Stop trying to increase your total posts you noob!!! :yahoo:
Under powering damage the subs?????? haha oh my god, i´m not even talking much about that myth, i damaged a 1000 watts sub with a 400 watts amplifier when i was a noob, and it was because i was clipping the hell out of it, underpowering doesn´t have anything to do with that...
you cannot hurt a sub by under powering it. ever.
it is clipping that leads to killing a sub and most of the time clipping is caused because the amps being used do not make enough power for the sub, so the user turns the amp beyond the point of clipping without knowing it.
ding ding ding ding correct answer...everyone stop bitching and fighting..if it happens again a 3 day vaca for everyone involved will be issued. now keep it clean (pun intended) and relax :drinks:
NoFearX18 said:
trainman0978 said:
Clipping is most of the time the problem but if you have a sub like Fi BTL and a 200wrms amp clip the shit out of it the sub will not blow but your amp will. But if you have 2000wrms amp and send clipped signal to your sub that is a different story.
