I already know what the big 3 upgrade is , 1/0 battery to engine block, another from battery to chassis, then battery to alt... Well thats where the problem ends, battery to alt, there isn't one, it actually runs to the starter, anyone know of any complications with this. ITs a 2009 chevy malibu, i can access my alt, but... where the f^%& do i hook it up to, should i leave the stock cable from battery to starter alone or junk it for the 1/0 wire, the other question is do i fuse that wire (battery to alt)?. Third question, i got my second battery in the trunk with an isolator, is this the proper set up or should i be running the wire straight from main battery to the trunk battery without the isolator??? please advise me
Thanks
I can answer a few of your questions. 1. fusing between alt and battery is not needed but is strongly advised as a saftey precaution. 2. get rid of the battery Isolator it only causes unneeded resistance . how big is your alt? you may want to do 2 runs of 1/0 to the back battery to improve flow
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
its a stock 130 amp alt, as far as upgrading, i would have to do that sometime later down the road, but i like the answer you gave me about the isolator, makes sense now why i'm getting voltage drop on the hard hits,
Leave all existing OEM wiring in place. The big 3 is in addition to the OEM wiring. Run the 1/0 from the positive terminal on the alt to the positive terminal on the battery. Battery negative to chassis ground. Battery negative to the alternator mount if you can, otherwise to the engine block.
If you have 1/0 going to the trunk, lose the isolator and make sure you have a 300amp fuse on each end of that 1/0 within 18 inches of the front and back batteries.
97 Maxima SE
Bunch of shit going in, check out the build
Lol there should be a bolt SOMEWHERE on your alt. And depending on how much power you are running, one run of 1/0 to the back should be fine. What all equipment are you using? That info could help a bit. :)
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
Just reread the question about the alt. There will be a plug that has some small wires on it, and there should be one fat wire going to a bolt on it. You want to put your wire on the same bolt as that fat wire (its probably 8 or 4 gauge).
97 Maxima SE
lol, i've checked several times in the past few days, thats why i haven't upgraded yet, its a 4 banger motor, so i don't have easy access to the alt but i can see the alt just fine, and i ran my hand from the battery and both positive wires run from battery to starter and another from battery to the fuse box with a 80 amp inline fuse... may i ask why i need to run 300 amp fuses, i'm only running 3 kicker cvx's 12's , a pa1-4000d amp, avh-3200dvd head unit. all my wiring is 4 gauge with a shuriken btk-80 which is 80 amp/hr rated at 1900 watts of surge power, the amp runs at 1 ohm stable 2200 watts give and take a few, but soon i'll upgrade the amp cuz i'm running at .67 ohm load on the amp, to my suprise it doesn't get hot, just warm...
You aren't fusing the equipment, you're fusing the wire. The wire is rated to 300 amps, so in order to allow it to run as much current as it can, you fuse it at 300 amps.
Fusing it lower won't hurt anything, but it will make it so that if the wire tries to pull more power then it will pop the fuse. Its when you fuse higher than the wire's rating that it becomes dangerous.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 0 Anonymous, 1605 Guests (See full list)
